Old 30th December 2003, 04:54 PM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default High efficient closed 2(.5)-way system
Hi all,
I'm currently looking for a new loudspeaker project. Untill now I've been playing with a 2 way BR monitor, with SS units. Because I'm changing to a tube amplifier I like to build someting a little more efficient. Have looked at various kits and designs but haven't found the right thing I guess. The new loudspeaker should be a monitor (2 or 2.5 way). I'm planning to use an active sub with it.
What I would like is:
1/ top quality units, now I'm using a 18W8546 and Revelator tweeter
2/ closed system, not bass reflex
3/ effeciency around 92dB for 2,83V/1m
4/ flat imp min 4 ohm
5/ f3 of around 80-100 hz is low enough
Like this one, very nice I think, but can't contact the owner ...
Can you come up with more ideas?
Ralph
Old 30th December 2003, 09:13 PM   #2
It all comes down to money. /hehe
High sensitivity designs... hmmmm
try this old thread.
PHL / ESg 3 way question - AR2
If money is no object, this 103db sensitivity tweeter sounds
excellent, $600 US. /hehe
http://www.wbvbeheer.nl/wbvportal/st...es/pdf62en.pdf
PHL midranges to mate with it.
Other resources. hmmmm... try
http://www.e-speakers.com/
Send Andre an email for high sensitivity design suggestions,
maybe he can brew something together.
Old 31st December 2003, 01:53 PM   #3
Ralph's Avatar
Hi thylantyr,
I did and he came with the following suggestions:
1) 2x PHL 1120 + G2 in closed box. F3 will be around 250 hz. So in that case I need a basssystem, like a one with a Lamba TD15 you wrote about.
Question about this configuration. I read in another thread that the TD15 is not very efficient in a closed box. Is that true? In that case I need to drive it actively.
2) 2x PHL 1240 +G2 in closed box. F4 will be around 90 hz. In that case I need a powered (sub)woofer crossed over at around 90hz.
Ralph
Old 31st December 2003, 03:54 PM   #4
Send a message via MSN to officeboy
You might find this design interesting.
http://home.hetnet.nl/~geenius/Auriga.html
Old 31st December 2003, 04:59 PM   #5
Millenium tweeter and two Accuton C95T-11 midbasses. Mind-blower if you can do/get a good XO! Relatively small sealed box.
High efficient subwoofer design DaveCan Subwoofers 88 14th December 2007 11:24 AM
System Q and closed boxes. The Dudster Multi-Way 8 17th January 2005 04:42 PM
Efficient spkr req' for battery system. Mark25 Multi-Way 9 3rd December 2003 08:52 AM
high efficient low midrange driver maik Multi-Way 3 27th May 2003 03:27 PM
Page generated in 0.08952 seconds (73.69% PHP - 26.31% MySQL) with 10 queries
