Old 30th December 2003, 03:47 AM   #1
seangoesbonk's Avatar
Default Parthenon - more than 80mm one way Xmax
This is ridiculous...
http://www.adireaudio.com/Files/Dan/Parthenon/
My girlfriend's sub is bigger than mine...
Old 30th December 2003, 05:45 AM   #2
Guss is offline Guss  Canada
Guss's Avatar
At the 2004 CES we'll be showing a 24" square baffle unit, with a Qts of 0.72 and an Fs of 7 Hz. Flat anechoic response to 6 Hz. And capable of over 66 liters of linear air displacement! That will generate reference level (121 dB SPL) output at 20 Hz, when sitting naked in a room - no room gain, no baffle, no box required. The first true dipole driver (not sub - no baffle, remember!) that can do reference outputs. With flat output to the single digits. How's that for a driver?
Now this is goddam low fs, sealed box lover save your bucks
Skinnyboy, I think the pionneer monsters are just been stunned by those adire with 12'' of Xmax isn't it
Old 30th December 2003, 12:22 PM   #3
Simply not the case, only when measured nearfied.
The baffle will roll-off 6dB/octave below 300Hz farfield.
sreten.
Old 30th December 2003, 03:03 PM   #4
5th element's Avatar
ye cannea chage the laws of physics, laws of physics, laws of physics, ye cannea chage the laws of physics, laws of physics, cap'n.
Its life jim but not as we know it, not as we........
Ok ill be quiet but sreten speaks truth.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 30th December 2003, 03:30 PM   #5
From Adire:
..figure in the $4500-$5000 range for most "normal" application.
The Dipole Bass Contingent is applying for second jobs and taking out additional mortgages even as we speak...
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 30th December 2003, 03:52 PM   #6
Pan is offline Pan  Sweden
I love it I love it I love it
/Peter
Old 30th December 2003, 04:04 PM   #7
I thought there wasn't a baffle to this thing? Why do they say square baffle then say there isn't a baffle?
Old 30th December 2003, 04:30 PM   #8
Send a message via AIM to zx3chris
Default Adire Audio's new motor (Parthenon)
"At the 2004 CES we'll be showing a 24" square baffle unit, with a Qts of 0.72 and an Fs of 7 Hz. Flat anechoic response to 6 Hz. And capable of over 66 liters of linear air displacement! That will generate reference level (121 dB SPL) output at 20 Hz, when sitting naked in a room - no room gain, no baffle, no box required. The first true dipole driver (not sub - no baffle, remember!) that can do reference outputs. With flat output to the single digits. How's that for a driver? "
looks interesting to say the least. I know adire has both enthuists and enemies here, anyone wanna discuss this monster?
here is the full link --> http://www.adireaudio.com/Files/Dan/Parthenon/
-chris
Old 30th December 2003, 07:02 PM   #9
BAM is offline BAM
Send a message via AIM to BAM
By this point, Dan's out of the world of audio and into the world of industrial linear motors. Provided he can find a springy suspension to hold the voice coil, he is to the point where he could effectively market an electrically-operated sonic jackhammer that would probably just power through concrete and stuff.
Old 30th December 2003, 07:17 PM   #10
RobM is offline RobM  United States
Send a message via AIM to RobM
That 24" square "baffle" is the cone, BTW. And assuming a rising magnitude to overcome the roll-off that's not strictly true (can be done easily electronically).
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
FS: Adire Audio DPL-12 needtubes Swap Meet 2 29th October 2005 04:00 PM
Adire Parthenon any Good? Paradise_Ice Multi-Way 10 12th July 2004 11:24 AM
Adire Audio kit-81m saletel Multi-Way 1 11th January 2003 06:25 PM
Page generated in 0.12263 seconds (76.46% PHP - 23.54% MySQL) with 11 queries
