2-way horn system - need some input
Old 3rd February 2014, 07:23 PM   #21
fpitas is offline fpitas  United States
Originally Posted by tinitus View Post
are these steep 48db xo slopes good ?
My experience, and that of a friend with a similar horn system, is that the LR8 crossover sounds bizarre, or even disturbing at times. He's happy with LR4 on the woofer and horn, while I've arrived at BW2 on the woofer and Bess3 on the horn. Perhaps with phase correction the LR8 would sound OK, but we haven't tried that.
Francis
Old 3rd February 2014, 08:38 PM   #22
Scott L is offline Scott L  United States
Default 8th order L/R
My experience using an 8th order Linkwitz-Reilly crossover has been nothing short of excellent. I've used it both in direct radiator and horn systems.
On a related note, my x-over unit is often the target of criticism by my fellow audiophile friends. But at the end of the day, I enjoy my system very, very, much.
Old 6th February 2014, 06:54 AM   #23
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
quote from Linkwitz
The caveat, though, is an increased difficulty in designing good systems with sharp slopes. The loudspeakers involved have differing transient responses, polar patterns and power responses. This means the system designer must know the driver characteristics thoroughly. Ironically, sometimes loudspeaker overlap helps the system blend better even when on-axis amplitude response is flat.
sometimes we know very little, and sometimes we know too much
Old 6th February 2014, 01:23 PM   #24
FredrikC is offline FredrikC  Norway
I get the WAF part Defo, this will always be a challange in horn systems.
Can't agree with you on smaller drivers being easier to integrate. What matters is to have a smooth blending of the power response at the XO frequency and a large enough forward lobe to cover the intended listening position and drivers that are well behaved through the XO region. DSP makes designing good XO's for horn systems a lot easier. A low XO frequency as you plan also makes this much easier, but going to low can make a compression driver sound strained, or a horn sound honky.
I have a green light on the following concept fro my GF:
48cm JMLC on top, with a large format driver.
Supertweeter just below angled 5 degrees upwards.
15" woofer in a cardoid - resistance enclosure also angled upwards.
18" inch woofers in the TV-bench.
Maybe not as cool looking as yours, but a fair compromise between visual aesthetics and forms follow function I think
2-way horn system - need some inputHide this!Advertise here!
All Horn System Build underslung PA Systems 33 20th January 2014 08:32 PM
Multi-way Horn System rocksteady40 Multi-Way 23 1st December 2012 12:06 PM
Mono Horn System-Edgar Show Horn? fergs1 Multi-Way 4 23rd August 2011 04:13 AM
2 way BR/Horn System minhaj Multi-Way 0 8th March 2011 06:36 AM
Three way horn system pelanj Multi-Way 28 11th August 2008 01:16 PM
Copyright ©1999-2017 diyAudio
