Help! Pair of Hi-FI cabs with 2 x 12"
Old 1st February 2014, 01:38 AM   #1
Metaltech66 is offline Metaltech66  United States
Default Help! Pair of Hi-FI cabs with 2 x 12"
Bought these cabs from a Habitat for Humanity "re"-store. A previous owner had removed all the woofers and one of the mids from each cabinet. Cutouts are 11.25, 4.25, 3.25. For woofer, mids, tweets respectively. 2 of each driver in each cab. I want to net an 8 ohm load. My question is what do most of you prefer between using 2x16ohm parallel, 2x8ohm series for woofers? These are sealed cabinets with a volume of 3.92 cu. ft. but would consider venting. 3 way setup in each cab with 6 drivers. Would consider going 2 way 4 driver per cab.
Old 1st February 2014, 09:30 AM   #2
SirByrd is offline SirByrd  United States
SirByrd's Avatar
2x8 ohm in series would net 16 ohms nominal, do you mean 2x4?
Old 1st February 2014, 02:31 PM   #3
fpitas is offline fpitas  United States
Either will work, depending on the circumstances. Generally though, you'll want closely matched drivers if you put them in series.
Francis
Help! Pair of Hi-FI cabs with 2 x 12"Hide this!Advertise here!
Gamber-Johnson cabs with Rola 12" full range audiomagnate Full Range 0 18th November 2013 03:05 PM
Custom 12 Gauge OFC home speaker cables 10.5 ft 1 pair Hi Fi audio Banana spade eisnerracing Swap Meet 0 26th October 2012 04:17 PM
Rare Stevens Trusonic 12" Woofer Hi-Fi FranStar Swap Meet 5 5th November 2006 08:55 PM
Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) saletel Swap Meet 0 27th October 2006 11:01 PM
12" Vintage Guitar Cabs rossco Everything Else 1 17th October 2003 09:23 AM
Copyright ©1999-2017 diyAudio
