Whilst I finish deciding (with all of your much appreciated help) which speakers I'm going to build for my audio setup, I want to start another project...
My neighbour has a set of Paradigm Atoms v3's (much like myself)and wants to complete a small HT setup. He knows i'm getting back into the DIY audio and is wondering if there are any kits out there that sound similar enough to the atoms to build a center and rear set to compliment them. Or even similar enough that these can be moved to the rear and new ones built for the front. Budget is very low due to the cost of the 'off-the-shelf' atoms ($199 CDN / pair). I know they use a Vifa 3/4" tweeter but do not know which. I assume that I can find a vifa mid that sounds similar enough to the paradigm's driver. Any suggestions? Thanks! |
#2 |
Has anyone responded to your post ? I was also looking for replacement woofer for a paradigm atom.
#3 |
Paradigm uses vifa? what else do they use? i thought they made all their own components
#4 |
Yeah i thought paradigm made their own drivers.
#5 |
I know Paradigm uses a Vifa tweeter in the Atoms.
For $200CDN, check out the Modulas - they're supposed to be marvellous, and while VERY different (aluminum woofer and tweeter), they should come in just under budget. |
#6 |
I've built the Modula MT, and spent less than $400 doing so- including buying the premade cabinets. If you already have tools for making cabinets and can get wood cheaply, then you can build a pair for well under $300.
They have excellent midrange, and even though I haven't heard the Atom, I can tell you that their bass absolutely destroys the Atom. How could it not? The atom uses a 5.5" woofer, and the Modula MT uses a 7" woofer with relatively long Xmax. I may be exhibiting some prejudice here, but I don't think anybody who's heard both will take issue with it. The Modulas have been compared favorably with far more expensive speakers. Oh yeah- so, are they similar in sound? I don't know, I guess if you want something that's similar in sound, there are things out there that use small poly cone woofers and 3/4" tweeters... but if I had the space, no way would I switch from what I've got now. |
#7 |
Actually, if budget is a concern, you could check this project out- http://zaphaudio.com/audio-speaker13.html
Shopping at Solen might make things easier, since you're in Canada. |
| Atom sized transistor... | gmphadte | Solid State | 1 | 21st August 2007 05:19 PM |
| paradigm atom and t-amps | jesserparker | Class D | 5 | 20th January 2007 10:24 AM |
| Paradigm Titan, Paradigm Phantom v1, a lot of help needed | duraznov | Multi-Way | 3 | 25th August 2006 03:36 PM |
| Newbie Q' - is this cheap speaker going to sound similar to the expensive one? | Gary Lightfoot | Multi-Way | 5 | 15th October 2004 04:36 PM |
| ACI Jaguars or similar project info. | Phil M | Multi-Way | 6 | 2nd May 2002 01:33 AM |
| Page generated in 0.08678 seconds (75.99% PHP - 24.01% MySQL) with 10 queries |
