Backloaded horns, do we want delayed bass, and how do we want it? - Page 3 - diyAudio
Old 24th January 2014, 08:46 PM   #21
Phenoholic Anonymus's Avatar
Short recap of the Visaton thread. A low Qes driver does not lead to much more efficiency compared with a high Qes driver. -Sofar so good - the low Qes does have a slightly less peaky output / more control. Interesting point made on the forum there: not Fs x 2 / Qes is responsible for the high cut off but the hornthroath dimension. Not so much the volume of the backchamber but it's throathdimensions. Good to see the Germans take this stuff so serious , complete with measurements in Visaton's own 7x7x7 meter anechoic messraum. And a seven plus page long discusion without any trolls.
This remark made me grinn, in essence a backloaded horn is a bassreflex enclosure with very, very good port to air adaptation.
Old 26th January 2014, 09:47 PM   #22
Originally Posted by Phenoholic Anonymus View Post
From a recent link in a HM art thread i found these numbers for the summation effect. Two sources need to be under 1.5 ms from each other to sum correctly. There is little information (links welcome!) about this effect in regards to Spl and frequency.
Two equidistant sources can be virtually any distance away from the listener and sum properly.
1.5 ms describes a distance sound will travel in time, and proper summation requires the arrival times to be within a quarter wavelength or so.
You can figure the wavelength by dividing 1130 feet or 347.7 meters (the speed sound travels per second at average room temperature) by the frequency.
A 1.5ms time offset is not problematic at around 180 Hz and below, but can be very problematic in the mid frequencies.
If the horn path of the BLH is around a wavelength behind the front output it can reinforce, sum, be in phase with the front output, even though it lags behind in time.
The problem with the BLH is if the upper frequency portion of the "horn" is not reduced enough in level by the folds or damping, the arrival time difference creates a ragged mid/high frequency response, "comb filtering".
Old 26th January 2014, 09:58 PM   #23
Thanks! Very clear, the more mid out of the "port" or horn the more problems.
Old 26th January 2014, 10:01 PM   #24
Yup, no free lunch, as damping the port upper response also reduces LF output, leaving one on the "horn" of a dilemma.
Old 26th January 2014, 10:19 PM   #25
I think in this respect, the bend is my friend, to damp some of the mid out of the horn.
Old 26th January 2014, 10:41 PM   #26
The back chamber volume can be used as an acoustical low pass filter, but don't count on much mid reduction from bends, just ragged response .
Check out the response of this four fold horn, I tried it with the speaker open also (like a BLH) response was little different.
LHC was a 4" speaker, LHD used an EVDH1A compression driver, LHGM used a sealed back 4".
LHC was the same speaker as LHD, with a couple 1/2" holes cut in the sealed back.
Old 26th January 2014, 10:52 PM   #27
Thanks, very insightfull Graph, same effect as with the Jericho horn 1 page ago, the response seems to fall due to the mass roll off > valley > peaks, peaks, far into the midband. "Mass roll off" get's stranger by the minute. In a straight horn i understand midrange coming out of the horn "i can see", but in a folded horn with a backchamber (Jericho not the graphs above), where mass roll off should prevent or at least damp signal above 500 Hz, weird.
Old 26th January 2014, 11:28 PM   #28
Theoretically these speakers should be unlistenable. Long horn (large amount of delay), smooth (no loss of midrange), no backchamber and almost no bends. This would be the posterchild for midrange content out of a backloaded horn ->
Old 27th January 2014, 09:05 PM   #29
And another example of a backloaded horn with lots of mid output out of the horn. I have come to the conclusion there is no way to stop the midrange coming out of the horn. Mass roll off, small volume behind the driver, damping, nothing will prevent mid coming out of the horn...
Nelson Pass on the Kleinhorn stuffing (pic above):
I ended up taking out all the stuffing except in the chamber before the throat. The sonic result was considerably improved over that of Part 1. The sound was more dynamic and lively, and I found that my approach of removing delayed higher frequencies from the horn did not improve the tonal
balance, coherence, or even the imaging”
http://www.firstwatt.com/pdf/art_kleinhorn1.pdf
http://www.firstwatt.com/pdf/art_kleinhorn2.pdf
I will stop worrying and learn how to love the backwave
Old 27th January 2014, 10:12 PM   #30
GM is offline GM  United States
GM's Avatar
Study up on human hearing perception and you'll find that below ~250-500 Hz [and much higher for a relative few] depending on the person and room conditions that our hearing acuity rapidly falls off, otherwise we wouldn't be able to tolerate the BW below this point in a typical room.
The 'name of the game' then is to use a low acoustic XO point same as the pioneers did, first by using low Qt motors coupled to a very high output impedance to maximize efficiency due to having little power available, then raising the driver's Qt as the amp's output impedance fell and its power increased over time until horn drivers wound up with anywhere from a ~0.5-1.0 Qts depending on the app with high power amps with tiny fractions of an ohm output impedance.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Smaller Fostex Backloaded Horns Persona Full Range 29 27th November 2012 12:03 PM
Best Firstwatt amp for backloaded horns? blue lander Pass Labs 55 24th May 2012 02:25 AM
WTB: Fostex backloaded horns, complete or just cabs jim_vt Swap Meet 0 13th July 2005 02:49 PM
Fostex Backloaded horns dreaded 42 Multi-Way 5 25th March 2004 04:27 PM
Bass Horns? Chris_SWE Multi-Way 7 7th January 2002 04:58 AM
Copyright 1999-2017 diyAudio
