Room Correction with PEQ
Hi jmbee, sorry for the delay to respond to your post. Looks great! Would you be able to share a bit more on how you achieved your results? Cheers, Mitch
Hello Mitch,
This result comes from using a pc based multi way crossover like discribed by Thierry here:
http://www.diyaudio.com/forums/pc-based/223805-easy-fir-crossover-pc-based-drc.html
Each H-P is measured then the response is shaped (equalized / filtered ) using rePhase to synthetise the convolution impulses, (2 x 3 ways ) and VSThost + VSTconvolver makes the all run.
Also is inserted an independant global equalizer to tame low frequency peak from the room modes.
crd
