Altec 406 - 8Y
Altec 406 - 8Y
Old 22nd September 2017, 11:32 PM   #41
GM is offline GM  United States
GM's Avatar
Greets!
I wouldn't, 13-1600 Hz is considered the 414's upper limit and these begin at 1800 Hz and 'want' much higher to use at 4 kHz-up.
Now got to find Bob's cab dims........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd September 2017, 02:21 AM   #42
GM's Avatar
OK, finally! Since size isn't an issue and your amp's 0.8 ohms output impedance + 0.5 ohms for wiring, etc., bumped Qts up an audible amount I increased it bit [~7.6 ft^3 gross] to get my preferred 30" wide [o.d.] baffle:
H = 58.5"
W = 28.5"
D = 7.875"
driver offset = 24.56" [~34.69" from floor]
vent offset = 49.125"
vent = 4" dia. x 0.75" hole or 1.75" x 7.187" slot
Recommend vertically offsetting the driver, vent at some acoustic or golden ratio to average out the baffle's width eigenmodes a bit, which will require mirror image baffles.
All dims inside [i.d.].
Recommend 18-19 mm BB, apple, bamboo, marine grade plywood or similar high MOE panel [> ~1.8 mil psi].
Any bracing needs to minimize vertical air restriction, so ideally tie all six sides together and brace/support the woofer. Personally just use board scraps and/or cheap closet rod dowels to tie it all together with one acting as the driver brace/support to mimic this or similar, though all the holes can be just a few huge freeform cutouts [pg. 4]: http://frugal-phile.com/boxlib/pensi...set-100711.pdf
Damp one side [one closest to driver if offset], top, back with 1" acoustic fiberglass insulation [OC703] or similar at least down to just above the vent to start.
GM
Old 23rd September 2017, 03:58 AM   #43
fred76 is offline fred76  Philippines
Originally Posted by GM View Post
Greets!
GM
Thanks GM...
Beyma TPL-150 ribbons could work, but considering their price, I think it's still best to stick with compression driver + horn up top. Thanks again!
Old 23rd September 2017, 04:51 AM   #44
GM's Avatar
You're welcome! Right, no need to 'fix what ain't broke'!
GM
Altec 406 - 8YHide this!Advertise here!
tube B 406 triode dick's cleo 4 suwaned Tubes / Valves 22 27th January 2013 03:29 AM
FS: PCB Accuphase E-406 + PRE HominisNocturna Swap Meet 7 1st November 2011 10:01 PM
WTB Altec 805B and some other altec stuff:) limono Swap Meet 9 11th October 2011 07:54 PM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 05:21 AM
Any one here using altec ? Russellc Multi-Way 27 9th March 2003 11:15 PM
Copyright ©1999-2017 diyAudio
