Using "The Edge" - diyAudio
Old 11th January 2014, 08:21 PM   #1
kendt is offline kendt  Canada
Default Using "The Edge"
Ive been playing around with the edge software to see what kind of results I could get using four mid drivers on an OB. Oddly enough the best looking response was with the drivers in a semi circle close to the inside edge. It looked pretty promissing.
I realize its only a starting point but is the software fairly accurate? Does it assume the response of the drivers to be flat?
Im just curious how far off the results might actually be in real life.
Old 12th January 2014, 01:15 PM   #2
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Yes Edge assumes flat response from drivers.
Did you try to simulate off-axis behaviour too? How high are you planning to cross to tweeter?
In an open baffle, directivity changes may get very interesting - a mix of dipole function/dispersion and driver diameter/group width determined dispersion. Usually we have a transition zone between these, with minimal directivity.
AINOgradient speaker project
Old 12th January 2014, 03:37 PM   #3
Default Diffraction & Boundary simulator
You could also try Jeff Bagby's "Diffraction & Boundary simulator" (Excel base). I used both Edge and his program to design my OB. I started with the Lowther LOB and adapted it to my needs.
Pierre
Old 12th January 2014, 06:19 PM   #4
I did not try off axis yet. I assume that is done by moving the mic position.
The mids and tweets are the same as the ones used in the statements so I will just use the same xover points since its already a proven design. The drivers are quite amazing but I'd like to add more to create a bigger sound.
Old 12th January 2014, 06:22 PM   #5
Pierre
Thanks! I looked at that software but didnt try it. Solen doesnt have the drivers in stock right now so I have some time before I can order the rest, so that will give me time to try it and compare the results.
Old 12th January 2014, 06:56 PM   #6
I did some more quick sims with the mic at various positions. It seems all the results show that the off axis response only affects the frequencies that are far outside the xover point. I would post the results but dont know how!
Old 14th January 2014, 12:00 PM   #7
Juhazi's Avatar
you can "lock" a measurement, then move the mic - lock result etc.
Then, press Shift-PrintScreen, go to your favourite Photo editor and paste the screen capture! I use PhotoScape Photoscape : Free Photo Editing Software (Photo Editor) Download
Old 14th January 2014, 02:42 PM   #8
Greebster's Avatar
Win7/8 (not sure about Vista)
Start, Accessories, Snipping Tool
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 12:45 AM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
How do you "edge seal" your MDF enclosures? The Paulinator Multi-Way 22 10th October 2007 02:38 AM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
Copyright ©1999-2017 diyAudio
