Old 28th December 2003, 09:30 AM   #1
Default F3 too close to XOVER?? Help!
I am designing a satellite/sub combo using a pair of Peerless HDS 164 drivers that I have. Using a 8.7 L box gives a Qtc of 0.707 and an F3 of 76.96 Hz. I wanted to crossover the speakers to a sub at less than 120Hz for imaging reasons, but would prefer this frequency to be nearer 80Hz. However, I am am concerned the F3 will then be too close to the XOver frequency... can anyone advise?
chris
Old 28th December 2003, 11:16 AM   #2
Volenti is offline Volenti  Australia
I can't see the problem? You'll simply end up with a steeper acoustical x-over slope than you would get with just the electrical side alone.
Old 28th December 2003, 11:19 AM   #3
So wouldn't this mean that if I crossover at 80Hz and the mid has rolled off too far there will be a dip in the frequency response?
This would be bad!
Old 28th December 2003, 11:42 AM   #4
your satellites will roll off at 80Hz with a classic Butterworth
second order roll off.
Further electrical crossover is difficult to achieve passively,
the box resonance thoroughly interfering with the filter.
for 120Hz you'll need an active arrangement, or just
use the bass management feature in an AV amplifier.
sreten.
Old 28th December 2003, 11:49 AM   #5
I was going to use an active 80Hz 24db/octave LR crossover, will this be too low?
Old 28th December 2003, 01:53 PM   #6
5th element's Avatar
Not a problem at all, I use the 12db natural roll off in the bass coupled with a 12db xover to get a 24db roll off in my speakers midrange cabinet. This is active though so passive may present more problems.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 28th December 2003, 02:07 PM   #7
Passive is exaclty sreten said it creates problems.
I just ran a few things thru LSPcad and came up with a passive network you could use however it would cost, due to large caps and inductors.
With just a simple 2nd order added you get the target 24db roll off but high Q so you get a substantial peak prior to this. So to compensate I added a series notch filter (L+C+R).
This worked like a charm and you get the desired response, 24db roll off linkwitz riley topology at 80hz
Xover as follows
Old 28th December 2003, 02:10 PM   #8
Thanks very much for the passive xover advice, however I already have an active crossover with selectable xover points and 24db slopes and wanted to use this... I guess this should make things easier anyway?
Old 28th December 2003, 02:18 PM   #9
Right appologies I made a few errors!
Anyway the other post was for a butterworth at 80hz
and its a shunt or paralell branch not series DOH!
Anyway here is the correct network
Old 28th December 2003, 02:20 PM   #10
Right and here just for completeness is an Active version!
Who knows Close Box for 18w/8531g00e ? amro Multi-Way 5 2nd January 2008 12:22 PM
2 Transformers close together... matic Solid State 4 7th December 2006 04:39 PM
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 08:58 PM
How close is close? Regis Multi-Way 1 13th February 2004 05:01 AM
how to close a thread Workhorse Forum Problems 3 20th January 2004 07:27 AM
Page generated in 0.12666 seconds (72.77% PHP - 27.23% MySQL) with 11 queries
