Why 2 tweeters?
I still don't understand why one might use more than one tweeter.
We have the technology to use a single compression driver to hit well over 120dB from a few kHz and up.
They're not small, granted, but I'd still expect them to integrate much better than a few domes all interfering with each other.
Chris
Chris
Well, I certainly agree. My latest project uses a radial horn in an MTM arrangement. The speaker above does use a waveguide, which may help integrate the three dome tweeters, but some lobing at very high frequencies is almost inevitable.
Using 2 neodymium tweeters of same type, which can be
mounted closely together, you have double displacement
volume:
That could make you go lower about 1/2 octave,
using 4 tweeters you can go lower 1 Octave,
as you need 4 times the displacement volume
per octave.
(given the tweeter's spec's allow it ...)
No one forces you to use all the tweeters to
the upper end, you can lowpass a subset of them.
The point is, that the drivers are mounted closely,
and there is a valid concept applied how the drivers
are used at higher freqencies.
Using a pair of conventional dome tweeters with
a large faceplate each and a distance far more
than one membrane diameter inbetween, does not seem
very elegant acoustically, i have to agree.
But using arrays of smaller drivers is a valid way to go ...
This model also makes use from arrays of smaller
drivers:
http://www.mcintoshlabs.com/Assets/Images/Products/XR100/XL_XR100_1.jpg
apart from all 'known issues', I wonder if two tweeters would be possible to cross lower than one ?
maybe someone will try it one day, just out of curiosity
but I suppose all this have already been measured ?
until then, I guess we can only go on speculating about it
I have considered using a 'helper' tweeter with a 1st order low pass to extend the crossover point lower. Didn't get to do it yet so I don't know how well it will work.
I would not run 2 tweeters full range. Even if it sounds great I will be seeing lobes in my head. The Keele array does something very unique where the wavefront is unified through clever design.
This is one of the most interesting discussions I have read. 🙂
I have LIKED D'Appolito type arrays ever since I heard the excellent Wharfedale E70:
This 1979 speaker had tremendous midrange presence, even if it's not strictly D'Appolito.
Here's the answers to some of our questions from 6moons audio reviews: Aurelia Cerica
• Different kinds of waveform behavior between tweeter and mid/woofers: Personally I find the even bigger problem to be that in a traditional D'Appolito configuration, the tweeter operates as a spherical radiator whilst the two symmetrical midranges tend to generate cylinder waves at the crossover frequency. While a cylinder wave fades at 3dB over distance, this doubles with a spherical wave to 6dB. The result is output instability over listening distance. To correctly balance a D'Appolito system is pretty difficult. Even in the best case the result will be more or less unstable. Is there a way to get a D'Appolito array to work properly?
When talking about real cylinder radiators (not WMTMW solutions), a single dome tweeter won't work satisfactorily as a line source. There is no sense in combining cylindrical and spherical radiators. Plus, it is very difficult to integrate a dome so that its radiating impedance remains as resistive as possible. To do that requires a pretty high crossover frequency which immediately causes interference issues with the mid/woofers. I thus emphasize that the only reasonable way to get satisfactory results is to use cylindrical radiators for all drive systems which must be used at the frequencies where their radiating impedances remain as resistive as possible, i.e. radiator lengths are proportional to the frequencies they generate. This is the only way to get a uniform radiation pattern and a smooth energy response and stability as a function of listener distance.
The Aurelia Cerica, BTW, is my favoured series wired solution that has good impedance at the expense of high SPL or loudness per volt. I hadn't thought about the way a single tweeter falls off at 6dB, whereas the twin woofers fall off at 3dB. 😎
I have also been puzzled by this. I noticed that those speakers that have two tweeters (and/or two midranges) sound very incohesive. Probably due to an increase of lobing.
attachment.php
Those Adams sound anything but incohesive. It should be noted though that they use a single tweeter and the two flanking AMT's are used for upper midrange so really it's an MTM.
A 3 tweeter arrangement was used by some to meet THX vertical dispersion restrictions at the time. Fleetwood Mac's Rumours 5.1 mix was done with a setup like that…the name of the speaker company is on the tip of my tongue, argh! Up in the San Fernando Valley of L.A., my brain keeps saying "Morel" but of course not, maybe sounds like it. M&K I think! 3 tweeters vertically stacked NEXT to a woofer. Acoustically, UGH, you think-but at the mixing console sweet spot, in that sound-treated studio, it sounded fabulous. Any lobing etc would not affect the mix location.
"Cylindrical tweeter...
Gryphon Mojo has a single conventional AMT pleated diaphragm planar rectangular tweeter.
Duelund Company resistors are used.
Crossover is regular LR4 acoustic at 2000Hz
Don't be fooled by some marketing phrases 😉
I wonder why we never see any published measurements from such "no compromise" speakers. 🙄
A lot of talk with great words, but nothing serious to support it. Thank you God for someone like Don Keele.
