Bi Wire X Over Help - diyAudio
Old 22nd December 2013, 03:57 AM   #1
Champ is offline Champ  Canada
Default Bi Wire X Over Help
I would like to add binding posts to a pair of vintage Braun L810s. The attached shows the usual - + single wire that is part of the original setup. Is it possible to wire the X over for Bi Wire duty and if so how do I do this? Thanks for any help on this. I presume it is not as simple as wiring 4 posts in parallel.
Old 22nd December 2013, 04:04 AM   #2
ashok's Avatar
You need to remove the board and trace out the connection of components before doing anything else. Mark the cables going IN and the leads coming out to the drivers with a marking pen on the crossover board. That way you will not make any mistakes, especially if you cut off the wires to remove the board.
From your picture alone nothing can be done. Make the schematic first.
AM
Old 22nd December 2013, 04:05 AM   #3
Einric is offline Einric  United States
Einric's Avatar
This should probably be moved to the multi-way area.
But, what you need to do is find where the crossover is split.
Generally the tweeter circuit starts with a capacitor, sometimes with a resistor and then a capacitor.
Generally the woofer circuit starts with an inductor,
Those will be your + points and you will need to separate them there.
Then follow the - post on each driver back to the crossover board, that will give you the - points. You may need to separate them there also.
However, if this uses a series crossover then all bets are off.
Old 26th December 2013, 01:27 AM   #4
My apologies gentleman for my tardiness. I am in Toronto and have had no power in my home for going on 4 days now, in sub zero weather. I'll have to look at this when things get back to normal
Bi-wire jumpers. Why not try this? GeneZ Multi-Way 22 5th December 2013 10:06 PM
Can you bi-wire using two different taps john dozier Tubes / Valves 18 19th March 2012 11:58 PM
A bi-wire FYI Cloth Ears Multi-Way 0 3rd November 2005 10:48 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Bi-wire, Tri-wire? Mos Fetish Multi-Way 5 15th June 2004 10:22 AM
Copyright 1999-2017 diyAudio
