Old 28th December 2003, 10:26 AM   #11
KYW,
in my case, according your advice it's better using a driver with fs=75-80Hz and Qt>0,7, but the Vas affect SPL on your spreadsheet result. It's hard to find 6" driver with big Vas to get SPL around 95dB.
I read somewhere that Vas can be ignored in calculation because there is no box, is it true?
Sheldon,
good idea even better with motorized baffle wing!
See you.
Old 28th December 2003, 11:17 AM   #12
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
Yup.
Of course it does. My spreadsheet calculates the absolute SPL for 2.83V applied and 1m distance. Most Box Calculation programes only provide a relative SPL calacuation. A larger Vas meas a more efficient Driver.
I am not surprised. You are running up against the little thing called Physics.
Of course not.
Sayonara
Old 31st December 2003, 05:54 AM   #13
apparently I reach the limit of small OB, with 6" driver and 40x60cm baffle size (folded), passive filtering, the result is not efficient, limited flat FR (200Hz to 12000Hz), so I drop to build it, am I give up to soon?
Happy New Year 2004, to all you guys, may audio be with you!
Old 31st December 2003, 07:55 AM   #14
Konnichiwa,
That comes from using unsuitable drivers (Low Qt and low sensitivity) and way too small size baffles (remember, folding gains you only minimal LF extension over the front section of the baffle on it's own.
Do the job right (Suitable driver, sufficiently large baffle) and the result will be very good.
Sayonara
sub amp question for MJK open baffle pforeman Full Range 7 15th May 2009 07:19 PM
Minimum size for open baffle driver? Javachip Multi-Way 2 28th June 2007 12:06 PM
Small, wall mounted open baffle? GuyPanico Multi-Way 5 10th November 2006 06:49 PM
Open Baffle - What's Your Image Size ? Will Planars & Exotics 3 12th May 2006 05:15 AM
open baffle loudspeakers and room size Russell Sit Multi-Way 29 7th July 2004 04:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
