Help me...
What do you call these? and where can I find these with 1/4" 20 internal thread? |
#2 |
looks like a camera mounting adaptor, try a camera shop.
#3 |
diyAudio Moderator Emeritus
Those are called "knife threaded inserts" for put reliable machine threads in wood and plastic. You can find an assortment at the high-end wood working shops and possible at in the speciality parts bins in some of the large hardware chain stores.
Rodd Yamashita |
#4 |
It is a threaded insert. You can find them at:
http://shop.woodcraft.com Go to the Hardware section and look under Knock down hardware. They have all sizes |
#5 |
If it sounds good... it is good! |
#6 |
THANK YOU GUYS.
Happy, happy joy, joy... I just ordered myself a whole lot of threaded inserts. I finally have the hardware to match my Black Diamond Racing Pyramid Cones... My life is now as close to perfect as can be... Merry X-mas everyone. |
#7 |
I had similar problem a few months ago and just gave up looking, so I might as well ask. Does anyone know of a supplier in or to Australia that has 4 and 5 mm threaded inserts (or something similar like a t-nut)
Cheers Jye |
#8 |
Probable should have mentioned that fastener supplier only go down to 6mm (because that is the smallest they use in furniture) and the hobby shops only stock imperial.
#9 |
Sure, any skateboard shop have 5mm t nuts, steel or aluminium according to your superstition
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
| Transformer fixing bolts | Prune | Parts | 2 | 24th September 2004 05:53 AM |
| Tiny Nuts and Bolts | PHilgeman | The Lounge | 3 | 24th May 2004 04:55 PM |
| Nuts and bolts for binding posts | Vikash | Multi-Way | 15 | 31st October 2003 08:04 PM |
| WHERE: Gold Hex bolts?! | Rarkov | Everything Else | 31 | 6th November 2002 09:08 PM |
| Nuts and bolts, and ground and ...caps | ftorres | Digital Source | 13 | 1st August 2002 04:28 PM |
| Page generated in 0.09792 seconds (77.52% PHP - 22.48% MySQL) with 11 queries |
