You are trying to clone something, right ?
Since you haven't answered my question about
owning a measurement system I will just ask,
are you willing to get one ?
I think it would be a shame not doing it properly,
without measuring. You bought super pricey drivers,
it would be only logical to get any kind od functioning
measurement setup so you know what you're doing.
What you ask here is similar to ordering a custom
made tuxedo over phone just saying you are male and
medium height .
medium height .
And I thought you were trying to clone SF Extremas .
You did ask a year ago if somebody would tell you the
cap value for tweeter XO.
For certain is you are now closer to clone them than
a year ago with a different bass-mid driver.
Dynaudio C1 uses technology close to your Esotars.
What am I trying to tell you?
Don't be a cloner. Learn about it and do it properly.
It's easy.
Whatever route you take, active or passive, you need
equipment to check your work!
A decent sound card, pretty much bunch of free software
to use, mic, all in all should be no problem.
Personally, I deal only with passive filters. Gathered
parts and magnet wire for 3 decades of diying.
XO project you're looking for can be fixed in no time
and be state of the art.
If you have the guts for it, I'll guide you online.
It's easy.
Usual "Throw some random speakers together and hope someone will do the digging and can get it working approach..."
Actually, having read the dynaudio car brochure, it's not looking too hopeless. I don't see much difference between the Esotar 110 tweeter and the T330D. Both 8 ohm (roughly 6 ohm DC) jobbies. So your prebuilt crossover ought to be doing the right things, since you have the correct 4 ohm 170mm polycone bass for it.
Looking at the bass unit's parameters, Qts 0.44, Vas about 10.5L, nothing hard there. Presumably it is balanced to fit in a car door, so big baffle.
As for a schematic, what is stopping you drawing it from your crossovers? You can then figure out how to apply any attenuation as necessary for the change of tweeter. I'd expect second order bass and third order treble here wired in phase. 2.4kHz XO, isn't it?
- EX2-650 Xover schematic needed
