http://www.wescomponents.com/CTS/QuasiMoDo.htm
it is pretty simple and seems to work fine,maybe not highest end anyone build this? |
#2 |
Full-range drivers seem to be favorite in dipole arrangements.
My latest project was high-SPL PA dipoles for treble use using 5" full-rangers. Unfortunately, their treble response isn't any better than the famous Radio Shack 8" full-range! (No whizzer, I guess) I find that by turning the treble knob all the way up and the 500hz mid to -6, I can get pretty good sound out of mine... pictures later. Full-range drivers are fantastic. |
#3 |
Dependant on where it was to be used
I would think about it for a while before committing to a design that had a tweeter underneath configuration. It seems that high pitched sounds emanating from below the height or plane of ear level frequently come across as un- natural. While I enjoy seeing and hearing innovative designs, this tweeter level thing is something that I don't believe I would want to be in the forefront of. regards Ken L PS if you do build it come back and let us know what you think -
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#4 | |
up at crossover, due to the relative offsets of the drivers. With a piezo horn, with its large offset it should be used above. I'd suggest checking out baffle step correction circuits for such a design, the builder appears to be unaware of the problem. If BSDC is included it also gives an easy way of boosting treble with circuit modifications rather than an additional driver. |
#5 |
I know this Monacor SP-200X quite well.
It's a shame to use it with such a cheap tweeter! Also it works very good in closed box. It also works fine in very wide open baffle,getting rid of the coloration of the box. Bartek |
| Page generated in 0.07977 seconds (73.80% PHP - 26.20% MySQL) with 9 queries |
