Old 23rd December 2003, 07:32 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default Which driver I must use?
Hi all,
I am very new at loudspeakers forum. So may be its a stupid question.
I have a TDA1514A based subwoofer amplifier (48-50W RMS @ 4ohm with 100Hz 12dB/oct. LPF). I have two 4ohm 16cm (6" dia) subwoofer driver. I gues they are good brand drivers (but I'm not sure, they are "WESTRA"). Anyway, the question is; Does one of my driver enough for my 50W amplifier? Does it make a lot of distortion @ full volume?
Thanks for your advices (in advance) ...
Best regards...
Old 25th December 2003, 07:14 AM   #2
Dxvideo's Avatar
Nobody will response?
Old 25th December 2003, 07:44 AM   #3
Guss is offline Guss  Canada
Guss's Avatar
If the question is if using a single driver would be enough for a descent subwoofer use, I guess it is not. I don't personnaly know westra and its too late to make a search for me... Well you could probably use your drivers in serie with your amp ending up with a load of 8ohm which is more suitable than 2ohm for your amplifier. Distortion mostly depends on your drivers xmax and you'll need alot for a sub use.
Why exactly dyou need a sub ? Car / HT / Stereo ???
Old 26th December 2003, 07:43 AM   #4
Dxvideo's Avatar
Thanks Guss,
I will use "the subwoofer" for my 4.1. In fact, I have 2 LM1876 and 2 TDA1514. So, for the satellites I use LM1876 (+/-22v 4ohm = 22W per rail) and for the sub, thats the problem node, I cannot buy a new subwoofer driver for now than I must use my 16cm 4ohm twin.. TDA1514A can drive 4ohm with 48W RMS power, in the bridge mode it can drive 8ohm and 100W RMS... Whats the solution?
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.83628 seconds (7.40% PHP - 92.60% MySQL) with 10 queries
