Foam insert inside soft domes
I use stacked layers of (1/8") S.A.E. rated F-11 Acoustical Felt. Vary the disk diametres so the resulting profile is dome shaped. These eliminate the cavity resonance and they reduce reflected output off the poke piece. Acoustical felt is made from natural wool and will work better than any synthetic material. Best second choice is high density fiberglass third choice is cotton or kapoc fiber. Hope this is of interest. Best regards Moray James.
