Old 22nd December 2003, 09:10 PM   #1
Default newbie question
Im sorry if this has already been asked or has a very simple answer. I searched, both google and here, and didn't find what I was looking for. Right now my receiver accepts the standard 5 speakers, 2 front, a center, and 2 rear. How would I go about adding to the amount of speakers? Is it even possible without replacing the receiver? TIA
Old 23rd December 2003, 12:57 AM   #2
MarkMcK is offline MarkMcK  United States
kambrian,
What you state as standard is standard for home theater surround called 5.1. If you want greater speakers in the surround format, there is another standard called 7.1. It consists of one center, two front, two side, and two rear. I believe it is available now (I am not much of a home theater buff) and does require the purchase of a new receiver with the 7.1 decoder.
I hope this is responsive to your question.
Good luck,
Mark
Old 23rd December 2003, 06:40 PM   #3
So there is no way to have like, 2 speakers per channel rather than one?
Old 25th December 2003, 05:32 PM   #4
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Default Why
why do you want more speakers.
PASSIONN
Old 28th December 2003, 07:22 PM   #5
I would like to have a floor standing speaker as well as a satellite for each channel. I know, I'd be better off getting better quality floor standing speakers but I have some satellites laying around and wanted to know if there is anyway to use them
Old 28th December 2003, 10:16 PM   #6
brsanko's Avatar
Default just watch your impedance
I guess you can hook as many speakers as you like to your ampifier just make sure your impedance doesn't get to low. If you run two 8 ohm speakers parallel you get 4ohms if you run them series you get 16 ohms. If your amp can handle a 4 ohm load do it that way if not go series just keep in mind you'll have less total power available that way.
PASSIONN
(Newbie) CSS Question bibster Tubes / Valves 8 24th January 2007 10:22 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
newbie question resident Tubes / Valves 10 4th August 2005 04:57 AM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.08023 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
