Dual woofer - diyAudio
Old 26th November 2013, 07:48 PM   #1
Default Dual woofer
Hi all
I am designing a pair of active speakers which will use 2x10" woofers, a single midrange and a single tweeter. The current plan is to position the drivers starting with woofer_1 at the bottom, followed by woofer_2, then the midrange and finally the tweeter at the top.
An alternative alignment which is more favourable for the power supply and amplifiers is to position the drivers starting with woofer_1 at the bottom, followed the midrange, then the tweeter and finally woofer_2 at the top.
The 'new' idea seems a little unconventional - is there anyone who knows whather it has any impact on the sound? I thought about the increased risk of lobing but as the woofers will not exceed 280Hz (and the won't be more than about 0,6m apart), that shoudn't be a problem.
Glad for any feedback!
Mark
Old 26th November 2013, 08:52 PM   #2
You end up with a much taller cabinet with the mid and
tweeter near ear level. FWIW that would smooth driving
the rooms bass vertical mode, but for most its very fugly.
rds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 26th November 2013, 10:46 PM   #3
OllBoll is online now OllBoll  Sweden
If you mount them WMTW or WWMT then basically nothing except increased output as long as they are close enough. If the woofers are far enough apart in the WMTW then there might be lobing where there wouldn't be in the WWMT.
If you invert one of the drivers you will significantly reduce even order distortion ( which is very nice in the bass where the copper sleeves and such doesn't do much ).
If you align them in a push-pull config you will get the drivers vibration to cancel which is also very nice, also here especially in the bass since the vibrations are so great.
Both of those setups can be done at the same time.
Old 26th November 2013, 11:47 PM   #4
frugal-phile(tm)
planet10's Avatar
Depends on how good the woofers are. What does this do to 3rd order products, do they go up -- if they increase (or stay the same) to greater than the reduced 2nd that might not be so good.
Anytime one can go push-push with woofers it is a good idea IMO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Dual Duty Woofer Build AcridSaint Subwoofers 9 20th March 2010 07:38 PM
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
New dual spider woofer GordonNHT Everything Else 5 13th June 2007 03:11 PM
Dual woofer placement dsrviola Multi-Way 9 3rd May 2007 01:31 PM
Dual Woofer TL? Phear Multi-Way 39 8th March 2004 08:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
