Altec Voice of Theatre Freq Response roll on / bass - diyAudio
Old 25th November 2013, 07:54 AM   #1
Default Altec Voice of Theatre Freq Response roll on / bass
hi, anyone can show me the BASS roll/on - in room - of the VOT??
thank sin advanced
cheers
P.S.:mine friend need a supersub!!
PAOLO
Old 25th November 2013, 10:09 AM   #2
djn is offline djn  United States
djn's Avatar
I never got mine down below 60hz-ish. I was running the 515s. They needed subs, but where great midbass horns.
My "Art" website http://home.comcast.net/~djnagle/site/
Old 25th November 2013, 10:49 AM   #3
OK,
60 Hz 2nd order??
Cheers
PAOLO
Old 25th November 2013, 10:53 AM   #4
djn's Avatar
Not sure what you are asking, but I let them roll off into the subs without a crossover on the Altec going down, just the subs going up.
Old 25th November 2013, 10:56 AM   #5
I 'm asking if the natural roll on of the woofer - in room - is 60 Hz , 2 nd order
high / pass ...
cheers
PAOLO
Old 25th November 2013, 10:59 AM   #6
gk7 is offline gk7
Originally Posted by inertial View Post
... 2nd order??
Itīs a ported box. For a "HEAD DESIGNER" you ask rather strange questions ...
Old 25th November 2013, 11:02 AM   #7
djn's Avatar
There is a mod somewhere on the net where you close off the bottom of the A7 and fill in the inside side flares so you turn it into a compression horn which raises the low end rolloff, but then you put an 18" JBL sub driver in the bottom. I heard it once and was very impressed and was going to do the same to my rig, but sold it and bought the Edgarhorns.
Old 25th November 2013, 11:52 AM   #8
yes,
excuse my ignorance about VOT,
I design direct radiation hi-fi speakers, only!
so 60 Hz 4th order high / pass?
cheers
PAOLO
Old 25th November 2013, 11:54 AM   #9
thanks
interesting, but mine friend want a separate big mono subwf ! biamp of course..
anyone can show this freq response of the VOT??
cheers
PAOLO
Old 25th November 2013, 12:03 PM   #10
Pano is offline Pano  United States
Pano's Avatar
With the stock (large) ports they don't go down very low. If the ports are better tuned, you can get almost another octave. In room response of mine has an F3 in the 30s. I'll dig up a response curve for you later today, after work.
But an F3 circa 50 Hz is common. These are not what I would call a "Supersub".
Take the Speaker Voltage Test!
TDA1562Q low freq roll-off DrLex Chip Amps 7 8th December 2009 02:37 PM
Altec Lansing Voice of the Theatre RacerXtreme Multi-Way 39 16th February 2008 08:45 PM
Bass Reflex - Port Freq. Response rjbond3rd Full Range 7 1st February 2008 10:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright Đ1999-2014 diyAudio
