JBL 2404 and DSP has someone done this? - diyAudio
Old 20th November 2013, 12:27 AM   #1
colofan is offline colofan  United States
Default JBL 2404 and DSP has someone done this?
I have a set of JBL 2404's that i would like to use in a HT setup again. With the newer DSP solutions available now does anyone have pointers on using DSP with the 2404's?
Old 20th November 2013, 04:58 PM   #2
Colofan,
Pretty wide open question, the desired crossover point, slope, and delay required are dependent on physical location of the tweeter compared to the mid range, and what type of midrange used. The actual response of the tweeter depends on what size baffle it is on, distance to the edges of the baffle, and what is beneath it- a big horn with reflective surfaces, or a cone/dome midrange are quite different.
Assuming your units both match, and match the usual 2404 response (a big ASSumption), applying about a 4 dB boost near 7,000 Hz and 12,000 Hz would flatten the response, since those dips occur in both on and off axis response.
If you were crossing at 24 dB per octave at 4000 Hz or above, the "bump" in response at 1600 Hz probably won't be audible.
Using a 12 dB per octave crossover below 4000 Hz (not generally advisable) would probably benefit from a low Q cut of around 10 dB at 1600 Hz.
DSP varies so much in definitions of "Q", can't tell you what specific value of "Q" and the exact amount of boost or cut would be required to correct the 2404 response.
Art
Old 20th November 2013, 05:24 PM   #3
speaker dave's Avatar
Those curves are from a really good one. The ring radiators vary all over the place. The 3 peaks that make up the response can be quite nasty. They did get somewhat better when they trained a lady to go around the perimeter with a ball point pen to crease the edge just inside the suspension point. (I kid you not. You can usually see the blue ink line.)
Anyhow, DSP on the actual measured individual responses should be a significant improvement. I would measure and average across, say +-15 degrees and EQ to that.
David S.
Old 20th November 2013, 05:42 PM   #4
David,
Some would use the word "sparkling" rather than "nasty" .
Creasing the suspension edge with a ball point pen without punching through the aluminum is quite a skill !
Art
Old 20th November 2013, 06:42 PM   #5
pos is offline pos  Europe
pos's Avatar
Good first hand info, thank you!
Is it possible to do the same on existing used drivers?
No loudspeaker system even approaches real life so there is plenty of room for interpretation - Greg Timbers
Old 20th November 2013, 07:43 PM   #6
I have many different options on midranges and making the enclosure from scratch. I have used driver before in both passive and active crossover systems just wondering about this new stuff with DSP about correcting the challenges out. I like the dispersion and sensitivity just trying to "tame" the driver a bit.
When I get done with the design and in testing mode I will post a bit more info on my specific driver set.
Time to go find my ball point pen. Thanks for the tips.
Also thanks for the tweak I will take apart the drivers and look for the mark.
Old 4th December 2013, 03:35 AM   #7
One other question is what DSP solution would you consider for "taming" the tweeter. I have seen a number of solution minidsp, dbx driverack...etc.
I already have the LinearXfilershop software so making digital filters not an issue. I can also test each tweeter in box to match up. The midrange I first though of since I have a couple of them is the Audax PR17-TX100 series though there is a new model out. I was also considering a FaitalPRO 6FE200 midrange.
This would be mated with a JBL 2118H for the midbass....I could go back to my passive/active crossover set and biuld a crossover but the thought of using a DSP to do some corrections with a computer and test data is inviting...
Anyone care to share their thoughts on building such a dsp based system?
Old 4th December 2013, 01:57 PM   #8
Pano is offline Pano  United States
Pano's Avatar
I have a pair of Fane copies of the 2402. They are difficult to match, for sure. I am using digital crossover and EQ at the moment to tame them. It works, more or less.
Old 4th December 2013, 03:58 PM   #9
Other than reading a bit about the Mini DSP, no experience with it, but if the LinearXfilershop software works with it, the cost would be lower than a DBX Driverack. Most reports are the AD/DA sound good.
I use the DriverackPA for my PA systems, I like having a "no computer needed" device. It is nice to be able to save all the settings for the variety of different set ups I use.
The DRPA has 2 PEQ bands for low, and 3 PEQ for mid and high, plus a 1/3 octave L/R EQ, more than enough EQ and delay length for most systems.
One "interesting" detail of the DRPA is it reverses polarity from input to output.
It also puts out a terrible "shotgun" noise when turned off or power lost.
The DRPA+ reverses polarity on the mid output, but may have fixed the turn-off transient.
The more expensive DBX models don't have these "features".
Art
Old 4th December 2013, 07:36 PM   #10
I am a little touchy about mini-dsp being in business 5 years from now. Maybe not an issue. Thanks for the feedback on the driverack systems and now they have come out with PA2 maybe wait a bit and do that....
Sale: JBL 16" K145, JBL 8" 2118, JBL 2404 HF, Fane ST-5022 (Edgarhorn), Klipsch K55V ZERO1 Swap Meet 3 3rd February 2013 11:03 PM
2 - JBL 123A-1 -- 12" woofers -- from JBL L88, but also L100 Jimmy154 Swap Meet 3 26th October 2012 07:13 PM
Horn enclosures w/ JBL 2226 and JBL 375. burtcheca Swap Meet 0 2nd August 2010 01:21 PM
specs of jbl 046TI-1S and jbl 726gs panduro Multi-Way 2 21st June 2010 07:45 PM
RS-232 cable for DSP-Amp Digisynthetic DSP-1400 Sabbelbacke Parts 0 9th May 2009 09:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
