Old 21st December 2003, 08:25 AM   #1
opus007 is offline opus007  United States
Default Sibilance
I know this has been discussed to death but I still have a sibilance problem.Recently I attenuated the tweeters with a variable resistor.This helped and made listening much better but I just can not tame that ssss.I thought it was the tweeter at first but if I completly turn the tweeter off with the variable resistor I can still here it coming through the midrange driver.Ok my receiver is not the best but a 400.00 Sony.I do not think it is the Sony as I have had the same speakers and others (telydyne acoustic research AR9's,polks and klhs) powered by the Sony with no problem.I also have a integrated amp and hooked up to it I have the same problem.The speakers I have the worse sibilance on are the ones I currently use which I used a pair of Fisher cabs and removed all drivers and crossovers and replaced with others.i have visited this forum for about a month now and most of the things everyone talks about I understand some... but most is way over my head.I listen to a lot of music through the directv music channels.I want to think it is a compression thing on directv as I get the same sibilance when just listening to tv without using the receiver.But when I listen to FM the siblance is there also(not as bad though)and also on some cd"s.It is wierd because certian programs or songs there is no sibilance and others it is terrible.The sound of these speakers are beautiful...except when the sibilance comes into play.What am I missing here???I have put a lot of time in these speakers and have been struggling with this forever.I have now 5 different sets of tweeters that I have changed and the same results.And as I said the sibilance is also coming through on the mid.I have changed the wiring from the crossovers to the speakers with cooper and then to silver then to the original and still the same.Is there a voodoo trick?Any ideas.Thanks...
Old 21st December 2003, 09:23 AM   #2
pinkmouse's Avatar
Hi Mate
It sounds like you have a cone breakup/resonance problem in your mid driver, rather than a problem with your tweeter. If you can do some basic FR measurements to find the problem frequency, then it is relatively easy just to knock up a bandpass filter to kill the troublesome peaks. Or if your drivers will cope with it, you could try lowering the crossover frequency and see if that helps.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 21st December 2003, 05:07 PM   #3
GM is offline GM  United States
GM's Avatar
Peaks in the ~3k-8kHz generates excessive sibilance, so I'm with PM, you need to isolate the mid and find the problem and damp it, though I prefer acoustic solutions over electrical to acoustic problems. Often, it's either the surround or its termination at the diaphragm.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd December 2003, 09:42 AM   #4
I think your amplifier oscillates a bit
You say its with all your speakers so check the output filter of the amp.... If the speaker impedance is getting too low (maybe due to a strange crossover config?) this can happen...
try another amp to compare?, and measure the freq/impedance of your speakers?
Old 23rd December 2003, 06:04 AM   #5
unfortunatly I do not have the equipment or knowledge to do those measurements.The crossovers are 3-way store bought and are rated 800hz and 5khz.Does this mean the woofer is at 800hz and the tweeter and mid at 5khz.if so isnt 5khz awful high and should i lower it to 3500hz or 2500hz?
Old 23rd December 2003, 06:23 AM   #6
whats the part number of your Pioneer midrange ?
Is it this one ?
http://www.partsexpress.com/pe/pshow...number=280-020
sreten.
Old 23rd December 2003, 06:40 AM   #7
Will is offline Will  Malaysia
I have 2 suggestions for you :
1) Coat the center of the midrange cone (dustcap) with some varnish/clear nail polish.
2) Add a 22 ohm (as a starting value) directly across the midrange's +/- terminals. Experiment with the resistance.
I have found these 2 to work effectively to dampen cone breakup on my Audax Kevlar 6.5" driver. Say goodbye to sibilance
Old 23rd December 2003, 01:20 PM   #8
only info I have on the mids are 5" graphite mids.Will pull one tonight after work and see if there is a serial. but the one you gave the link too is not it.Also is that a 22ohm resistor?
Old 23rd December 2003, 01:30 PM   #9
Yes that's a 22ohm 5W (white coffin) resistor
Old 23rd December 2003, 01:59 PM   #10
I still think the impedance of the filter is getting too low.....
because sibilance sounds through mid and tweeter as well sounds like oscillation..... and the other amp couldn't handle it too...
Is there a wrong impedance-correction network? do you have a link to the filter and speakers? The impedance measurement is not that difficult (youll need a sine-generator, 1kohms resistor and a true-rms meter)....,
Or try this: place a resistor of 4 ohms/10W in series with the speaker (just for a test) to make sure that the impedance is not getting too low, if the problem is still there it must be either indeed a driver problem, or a filter-problem (resonance in a coil/zobel network, wrong connection somewhere, faulty capacitor in both left and right speaker...)
If the problem is gone (with the resistor) the speaker will sound quite different (with the series resistor attached)..... and then its also a problem in the filter causing an impedance fall....
The above test is quite easy to check....
good luck!
Fostex Sibilance? wixy Full Range 8 4th April 2008 05:20 PM
Sibilance GOWA Multi-Way 14 9th August 2007 03:01 AM
Sibilance Distortion on SMGs alexmoose Planars & Exotics 5 21st May 2007 09:21 PM
Sibilance problem DerrickM Multi-Way 4 4th May 2007 03:21 AM
Which cap would help reduce sibilance? andy2 Multi-Way 4 12th December 2005 09:09 PM
Page generated in 0.13158 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
