Old 20th December 2003, 10:59 PM   #1
Jhovis is offline Jhovis  United States
Default Impedance Question
I'm trying to connect two subs to one amp.
Situation:
Two 4ohm dual voice coil subs in separate cabinets.
One 4ohm amp.
Problem:
How do I get those two separate subwoofers connected to one 4ohm sub amp and maintain an impedance of 4-8 ohms?
Assumption:
I assume I can wire the two voice coils on each sub in series and that would bring the impedance of each sub driver up to 8ohms? Then I would have two 8ohm subs instead of two 4ohm subs.
If that is true and I then connect them in parallel to the amp, will I then have a 4ohm load?
jeff
Old 20th December 2003, 11:12 PM   #2
Yes. You have it.
You thought I had it!?... I thought you had it!
Old 20th December 2003, 11:41 PM   #3
Thanks!
jeff
Old 20th December 2003, 11:49 PM   #4
Tube_Dude's Avatar
Yes!!...then you will have a 4 Ohms load!
Jorge
Impedance question jetbat Tubes / Valves 4 8th May 2009 06:35 PM
diy impedance question caza125 Multi-Way 3 4th September 2006 02:54 AM
question about impedance glazarou Multi-Way 10 26th August 2006 05:30 AM
Impedance Question jwatts Multi-Way 10 2nd June 2006 12:31 AM
Another Impedance Question Sherman Multi-Way 25 19th March 2004 12:39 AM
Page generated in 0.07490 seconds (71.12% PHP - 28.88% MySQL) with 10 queries
