OBERTON drivers ? If yes, why not anyone using them - diyAudio
Old 10th November 2013, 08:58 PM   #1
Elias is offline Elias  Finland
Elias's Avatar
Default OBERTON drivers ? If yes, why not anyone using them
There is this European driver manufacturer Oberton
Home
They seem to have many interesting drivers
Has someone actually used these ? Those 10" and 12" midranges / midbasses for example
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 10th November 2013, 09:59 PM   #2
Some of their compression drivers looked quite good on paper. Hence I don't trust something to look very good but have next to no information on the internet about.
Old 10th November 2013, 10:09 PM   #3
KSTR is offline KSTR  Germany
KSTR's Avatar
Oberton drivers have a good reputation among european PA builders, both DIYers and professionals. Nothing special, but very OK drivers. They get underrated because of their country of origin, it seems.
Old 10th November 2013, 10:11 PM   #4
Elias's Avatar
That may be part of the problem: since no information available no one dared to use them, and since no one used them no information available
Well, the availability seems to sparse. Only few online shops has them.
Old 11th November 2013, 03:41 PM   #5
Elias's Avatar
Oberton 8MB201 was tested in an German magazine last year.
It got rather good marks
Die Klirrwerte sind sensationell niedrig,
selbst bei 105 dB erheben sich K2 und K3
nur stellenweise über die 1-%-Marke und
zeigen keinerlei Ausreißer. Der Wasserfall
zeigt, dass die wenigen Resonanzen harmlos
sind, sie klingen schnell ab.
translation powered by googel:
The distortion values ​​are sensationally low,
even at 105 dB, K2 and K3 raise
only locally on the 1 -% level and
show no outliers. the waterfall
shows that the resonances few harmless
, they disappear fast.
People no want to use drivers with "sensationally low distortion" ???
Old 11th November 2013, 09:25 PM   #6
Nissep is offline Nissep  Sweden
Well, i have used the coaxial 8cx with good results.
Welcome to Flickr!
The could have done a better job on the throat and the voicecoil is sticking up a little to much.
But for a battery drive partyspeaker they worked out really nice.
I used a minidsp+miniamp.
Then i used autoeq on REW to make them play as flat as possible way past the crossover point.
Applied a seccond order LR at and adjusted delay until the phase looked good.
Old 29th September 2014, 09:29 PM   #7
Welcome to Flickr!
I went through your results, and one thing that caught my eye was the lack of energy after 10 kHz. Was this a result of your implementation, or is there really nothing to expect after that boundary from these drivers?
I'm currently looking for a suitable 8-10 inch coaxial driver for my open baffle project, and the Oberton 8CX and BMS 8C250 are currently strong candidates for the "next step".
Old 29th September 2014, 10:10 PM   #8
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
18NXB700 - Russian distributor 18NXB700 page..
flesh flash flush
Old 29th September 2014, 10:23 PM   #9
Give me a day to find the rest of the measurements.
Unfortunately i no longer own these.
But if you ask me and my bad memory, at the levels these were made to play.
You didn't miss any high at all.
Old 29th September 2014, 11:34 PM   #10
What I'm looking for is a coaxial 8" driver that's good for a project that's looking to destroy anything in the High End of loudspeakers under ten grand. The BMS holds a place close to my heart for anything like this for it's ring diaphragm compression driver, which I have some experience with. So I need much justification to go with the Oberton, which isn't that much cheaper than the BMS...
Philips FR drivers/ EV fullrange drivers/ Vintage Wharfedale x/overs devilsindetails Swap Meet 2 28th November 2011 01:09 AM
FS: RS LX-4 drivers (Linaeum monopoles and 4" kevlar drivers) JohnG Swap Meet 2 2nd November 2011 02:00 AM
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 04:19 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 05:34 PM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 10:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
