What are the options for a good project with the following specifications? I have four of them in hand. At the moment I am doing a open baffle 2 way Jordan with Jx53 and Jx150 with a ribbon super tweeter. Or should I sell them off instead?
Power==175W RMS PEAK==350WATT Imp==4 ohm RDC==2.8 ohm Fs==25Hz Qes==0.62 Qms==2.9 Qts==0.51 Vas==248L(8.75cu.ft.) Xmas==+/-6mm(0.24”) Travel==1.1” No%==0.627 BI=6.8TM Mms==64G Sd sq.M.==0.0531 MAGNET==56oz SIZE==12” Features 2" 2 layer voice-coil on aluminum bobbin chrome ion deposited polypropylene cone with stress relief rings Rubber surround All the spec numbers means nothing to me at all, no clue! Regards, Chris |
#2 |
Well, they sound like pretty decent drivers, good enough for a pair of push-push dipole subs....
BUT I think you'll have trouble integrating them with your JX150, which puts out pretty good bass in the Jordan factory alignments. I think you'll be happier with a setup where the JX150 is your LF driver.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
They sound like "free air" car drivers. Even in isobaric configuration you'd need a sealed box of 4 cu for each pair. Pretty good drivers for stereo open baffle subs though, but this can get very complicated, see Linkwitz Labs. |
#4 | |
http://www.ejjordan.co.uk/systems_frameset2.htm
#5 | |
#6 |
I think the output of 4 x 12" drivers with such a small xmax will be marginal. Sealed or vented they will have reasonable output. You need a lot of displacement to get any real output of a dipole!!!
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#7 | |
Displacement means diameter of the 12" or horizontal movement of the diaphragm along X-axis? |
#8 |
Banned
mount them in the floor... I did it with a single 10inch driver, and the bass was the best.. lol for a $35 10inch woofer with 3mm x-max..
#9 |
If I want to use it in the basement that means I have to dig a hole in the concrete foundation in order to mount them in the floor. That may be too much work to smash thru the foundation. What about paper/cardboard tubes? Any suggestions?
#10 |
If you use cardboard tubes you need two around 6 feet tall.
Use a pair of drivers in clamshell / isobaric configuration per tube. Stuff well and you'll get a Q of around 0.7 at 35Hz. |
| Dynaudio 30W54 12inch woofers | hottyson | Swap Meet | 2 | 18th August 2008 08:49 PM |
| 12inch coaxial | lazenna | Multi-Way | 2 | 13th June 2008 10:23 AM |
| McCauley 12inch from EAW | matze84 | Multi-Way | 0 | 20th February 2008 06:14 PM |
| which 12inch subwoofer? | TWOJZ | Car Audio | 12 | 17th December 2007 06:50 AM |
| FS:2 x 12inch Baldwin speakers | MichaelPublic | Swap Meet | 0 | 19th June 2007 11:18 PM |
| Page generated in 0.12264 seconds (76.93% PHP - 23.07% MySQL) with 10 queries |
