What to do with 4 12inch woofers?
Old 20th December 2003, 05:34 PM   #1
chris ma is offline chris ma  Canada
chris ma's Avatar
Default What to do with 4 12inch woofers?
What are the options for a good project with the following specifications? I have four of them in hand. At the moment I am doing a open baffle 2 way Jordan with Jx53 and Jx150 with a ribbon super tweeter. Or should I sell them off instead?
Power==175W RMS
PEAK==350WATT
Imp==4 ohm
RDC==2.8 ohm
Fs==25Hz
Qes==0.62
Qms==2.9
Qts==0.51
Vas==248L(8.75cu.ft.)
Xmas==+/-6mm(0.24”)
Travel==1.1”
No%==0.627
BI=6.8TM
Mms==64G
Sd sq.M.==0.0531
MAGNET==56oz
SIZE==12”
Features
2" 2 layer voice-coil on aluminum bobbin
chrome ion deposited polypropylene cone with stress relief rings
Rubber surround
All the spec numbers means nothing to me at all, no clue!
Chris
Old 20th December 2003, 05:47 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Well, they sound like pretty decent drivers, good enough for a pair of push-push dipole subs....
BUT I think you'll have trouble integrating them with your JX150, which puts out pretty good bass in the Jordan factory alignments. I think you'll be happier with a setup where the JX150 is your LF driver.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 20th December 2003, 06:28 PM   #3
R.I.P.
On an open baffle ?
They sound like "free air" car drivers. Even in isobaric configuration
you'd need a sealed box of 4 cu for each pair.
Pretty good drivers for stereo open baffle subs though,
but this can get very complicated, see Linkwitz Labs.
sreten.
Old 20th December 2003, 08:58 PM   #4
leadbelly's Avatar
On an open baffle ?
My statement is still correct; Jordan does not have an open baffle factory alignment for the JX150.
http://www.ejjordan.co.uk/systems_frameset2.htm
Old 20th December 2003, 09:19 PM   #5
R.I.P.
OK, I'll rise to the bait, correct but totally pointless in context.
sreten.
Old 21st December 2003, 12:35 AM   #6
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
I think the output of 4 x 12" drivers with such a small xmax will be marginal. Sealed or vented they will have reasonable output. You need a lot of displacement to get any real output of a dipole!!!
Old 21st December 2003, 12:46 PM   #7
chris ma's Avatar
Displacement means diameter of the 12" or horizontal movement of the diaphragm along X-axis?
Old 21st December 2003, 01:09 PM   #8
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
mount them in the floor... I did it with a single 10inch driver, and the bass was the best.. lol for a $35 10inch woofer with 3mm x-max..
Old 21st December 2003, 01:45 PM   #9
chris ma's Avatar
If I want to use it in the basement that means I have to dig a hole in the concrete foundation in order to mount them in the floor. That may be too much work to smash thru the foundation. What about paper/cardboard tubes? Any suggestions?
Old 21st December 2003, 02:50 PM   #10
R.I.P.
If you use cardboard tubes you need two around 6 feet tall.
Use a pair of drivers in clamshell / isobaric configuration per tube.
Stuff well and you'll get a Q of around 0.7 at 35Hz.
sreten.
What to do with 4 12inch woofers?Hide this!Advertise here!
Dynaudio 30W54 12inch woofers hottyson Swap Meet 2 18th August 2008 08:49 PM
12inch coaxial lazenna Multi-Way 2 13th June 2008 10:23 AM
McCauley 12inch from EAW matze84 Multi-Way 0 20th February 2008 06:14 PM
which 12inch subwoofer? TWOJZ Car Audio 12 17th December 2007 06:50 AM
FS:2 x 12inch Baldwin speakers MichaelPublic Swap Meet 0 19th June 2007 11:18 PM
