Hi Folks
A good mate has got some old 8" Tannoy drivers, (pics below). They need full recones, and unfortunately the crossovers are mising as well. Anyone recognise them? Model numbers would be handy for sorting out recone kits. Thanks in advance
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#2 |
Back view...
#3 |
Hi there,
Give Falcon acoustics a call they have a company called DC Boultons which is part of Falcon Acoustics. They recone loudspeakers and specialise in larger units like the tannoys.Ive just got all 4 bass units in my Kef 105.3 re foamed by them and they are perfect and they offer a great service. Here's a link for them http://www.falcon-acoustics.co.uk Falcon might even be able to help you out with the crossover aswell. Hope this helps Anthony Kirby |
#4 |
They look like Tannoy SGM-8 speakers.
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits... |
#5 |
Try Tom at www.speakerbits.com.au as he might be able to supply factory surround components. He's done a couple of mine previously (15"- ers) and the workmanship was excellent (absolute gent and very knowledgable/professional too). Either he, or someone on the Yahoo Tannoy group might be able to tell you the UK supplier and xover info too. Even if you have to import them from Oz, they're small and postage won't cost much.
It's unlikely that you'll need to replace the cones, just the surrounds. If you do the lot with non-factory bits, they wont be Tannoys any more. The horn in all the older Tannoys is a CD type and needs FR compensation for falling response at higher F's. The hard part will be the tapped inductor/autoformer, but if you have some measuring gear, you'll be able to select a single one to work. I've never actually seen a pair of 8" before; they're something I'd like to try in an Oris/Azura type horn. |
#6 | |
Sounds great. But where to find Tannoy DC’s? Tannoy does not sell separate units so you have to rely on spares. But they do sell these: http://www.tannoy.com/product.cfm?D=2&ID=78 They come complete with a high quality x-over. I’ve put these in a 20L closed box. But a back-loading horn ... Cheers |
#7 | ||
#8 | |
Cheers |
#9 |
Thanks Guys
The reason that we were thinking of full recones is that some of the drivers have been "repaired" previously, and cleaning up the originals might be more bother than it is worth... The tweeter seems to be the standard pepperpot variant, with a 2" VC, so that should be easy enough to find. As for the Xovers, I am aware of the falling response problem, and if I have anything to do with it, the system will be active, with the fall off electronically corrected. Using them in a horn sounds interesting, however with only a 8" mid, they may well need some extra help at the bottom, after all, even the 12"s never went super low!
| Tannoy 10 inch Dual Concentrics | JRKO | Multi-Way | 120 | 10th April 2011 12:14 PM |
| Tannoy HPD 315 A dual concentrics | Puggie | Swap Meet | 0 | 13th March 2006 12:12 PM |
| X-tealth dual concentrics? | Pallas | Multi-Way | 1 | 16th August 2005 06:09 PM |
| Page generated in 0.11188 seconds (77.49% PHP - 22.51% MySQL) with 11 queries |
