Double woofer design - measure together or separately? - diyAudio
Old 6th November 2013, 07:26 PM   #1
btntx is offline btntx  United States
btntx's Avatar
Question Double woofer design - measure together or separately?
I need a little advice regarding designing a crossover for a double woofer speaker. I have done impedance and frequency response measurements for each driver. But do I need to treat the two woofers as one driver and wire them together as intended and run the measurements that way? And then use those results to model the crossover and Zobel circuit? I want to make sure that I approach this the right way.
Thanks.
Old 6th November 2013, 09:46 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
Would a zoebel by any other name sound so sweet? Some sort of impedance compensation is often necessary, whether you call it a damped 2nd order filter or a first order with a zoebel is somewhat immaterial- I don't get too hung up on labels, crossovers are best viewed holistically rather than incrementally.
Originally Posted by sreten View Post
Real design seldom needs a Zobel.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 6th November 2013, 11:51 PM   #4
oldmanaudio's Avatar
If you want both woofers to crossover at the same Frequency I would treat them together. That is if the combined resistance is not to high. If the total resistance turns out lower the size of the inductors needed in the crossover will be lower with less resistance and less loss.
Also component count will be lower.
About the woofer:Passive Radiator or Double Woofer for Vetend kevinlin1013 Multi-Way 8 12th January 2011 06:13 PM
Where to measure max. input voltage to woofer MCPete Multi-Way 0 9th December 2009 07:41 PM
measurement TS in a double voice coil woofer hiendaudio Multi-Way 2 3rd February 2004 05:31 PM
Driving double coil woofer cld1354 Solid State 1 23rd April 2003 11:28 AM
Copyright 1999-2017 diyAudio
