crossover calculators and impedence - diyAudio
Old 5th November 2013, 02:47 PM   #1
Default crossover calculators and impedence
Hello all !
So I've been fooling around with online crossover calculators and got wondering.... For say a two-way speaker it asks for the impedance of each driver in order to do the calculations. So my question is if I am adding resistors to each driver to make each one a 16 ohm load should I be entering in the original impedance (sans resistors) of each driver into the calculator or the impedance after adding resistors ? Values change so drastically when you add resistance to the mix !
Old 5th November 2013, 03:04 PM   #2
picowallspeaker's Avatar
A resistor dissipates energy, it doesn't convert it into acoustical energy- well, speakers are rather inefficient too !
However, the answer is a no-no.
The online calculators might be of some utility for high pass only, as woofers are rather unpredictable..
Old 5th November 2013, 08:14 PM   #3
I am actually looking to run a fullrange driver with a tweeter to top off the top end. So the tweeter is a 6 ohm. The impedance curve show by seas shows that it stays between 6-8 ohms in the frequency range I would be using it for. So I am looking at using it from about 10 kHz up. So I've put a 10 ohm resistor on it to make around 16 ohms. The fullrange is a 4 ohm with a 12 ohm on it.
Old 5th November 2013, 09:09 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
I think you need to back up a notch or three. It sounds like you're trying to use resistors to make your drivers 16 ohms to match the output of a tube amplifier- this is not a good method. Crossovers are fairly complex, and the impedance in the passband isn't the only issue.
Can you be very specific about what you're using and how?
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 5th November 2013, 11:16 PM   #5
I am making both drivers 16 ohm to make an 8 ohm load when run in parallel. I am using just cap for the tweeter, It's not for my tube amp.
Old 6th November 2013, 12:34 AM   #6
AllenB is offline AllenB  Australia
OK, are you also to be running these in parallel physically? Ie, will they be in the same cabinet, or beside each other or something else?
Old 6th November 2013, 04:31 AM   #7
You don't put any resistor in line with a woofer- at least not more than 1-1.5Ω in some ( sealed enclosure ) case - and the capacitor decouples the tweeter
from the amplifier. Look at any design whatever it may be fullrange + tweeter
or woofer-mid-tw...the resistors in series alone play a different role.
Old 6th November 2013, 08:53 AM   #8
giralfino's Avatar
That is plain wrong. If you use a cap then you have a crossover, and the drivers are not seen as separate entities anymore. The impedance will be a combination the of drivers impedance and the crossover.
Adding a series resistor to a woofer is basically a no-no because you are wasting energy without a real benefit. If your amp cannot drive a 4 Ohm driver then change driver or amp. Mixing a 4 Ohm woofer to a 6 Ohm tweeter doesn't pose any problem.
Another problem I see is running the fullrange without a low pass filter. You'll have lobing problems in the treble.
Ralf
Old 6th November 2013, 11:05 AM   #9
So what I am using is a Seas FU10RB 4 ohm fullrange with just an 12 ohm resistor run in parallel with a Seas 27TBCD DXT tweeter 6 ohm with a 10 ohm resistor and a capacitor. (I do have a pair of Seas FU10RB in 8 ohm available if needed). I am not worried about a lowpass filter as of yet as my amp will let me control it.I would just like to start with a simple first order crossover and expand along the way. I am looking to learn along the way and expand as a go. I do see many coaxial speakers with just a capacitor on the tweeter and they seem to work okay for what they are. The drivers I have are in a sealed box currently and I could modify to port them if needed. Basically what I am looking for is a 6 ohm load or higher as the amp says 6-8 ohms.
Old 6th November 2013, 11:07 AM   #10
Ralf
So should I lose the resistor on the woofer and put a higher value on the tweeter ?
Online crossover calculators --- worth anything? GaryM44 Multi-Way 25 18th May 2013 02:52 PM
Use "Impedence" or Re for crossover calculator? critofur Multi-Way 9 10th April 2008 02:00 PM
crossover and impedence question dvd_diyer Multi-Way 2 12th April 2004 11:31 PM
Impedence and Crossover affects squidbait Multi-Way 10 2nd April 2004 05:17 PM
impedence with self made crossover trespasser_guy Multi-Way 2 19th September 2002 12:39 AM
Copyright 1999-2017 diyAudio
