c-coil (toroid) in 2.5 way system - diyAudio
Old 5th November 2013, 10:12 AM   #1
Default c-coil (toroid) in 2.5 way system
Just wondering if this is fine to use toroid c-coil from jantzen in 2.5 way system for lower bass output? In such system boths midwoofers are connected in parallel. One play mids(<2200hz) and lows and one only lows below 300-400hz. I thought to use c-coil for lower midwoofer. but can anybody tell me if c-coil(toroid) would have negative(audible) effect on "higher" midwoofer?
C-Coil - Jantzen-audio.com
Old 5th November 2013, 11:13 AM   #2
DUG is offline DUG  Canada
mH of inductor?
Schematic?
Adding an inductor will not make more bass.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 5th November 2013, 11:46 AM   #3
4,7 mH
schematic (hi-pass for 27TDFC, lo-pass for U18RNX/P woofers):
Old 6th November 2013, 07:14 AM   #4
Since nobody knows I will try with c-coil and check if it is good idea
Old 6th November 2013, 08:34 AM   #5
giralfino's Avatar
Troels did use such a coil in a project. See here: DTQWT-mkII
But IMHO for a 4.7mH inductor I would stay with a more conventional and cheaper cored coil. One with DCR < 0.3 Ohm would cost less than half the one you are proposing.
Ralf
Old 6th November 2013, 09:52 AM   #6
diyAudio Member RIP
L3 will not affect the bassmid driver. It does not
have to particularly low resistance in any sense.
L2 needs to be beefy to handle both drivers well.
rgds, sreten.
Old 7th November 2013, 07:54 AM   #7
wolf_teeth's Avatar
FWIW...
I had a pair of 4.7mH C-Coils that measured 2.7mH and 2.9mH, so please measure for best results. I also had a pair of 1.5mH that were just fine.
YMMV,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Coil replacement TO COIL 330UH IN THE pathway regulator 7809 ? dazzz Parts 14 16th September 2013 04:52 AM
Centre tapped coil with in a coil - inductance? peskywinnets Solid State 1 31st March 2010 05:13 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 03:49 AM
Copyright 1999-2017 diyAudio
