diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Peerless BC25TG15-04 measurement file (http://www.diyaudio.com/forums/multi-way/245317-peerless-bc25tg15-04-measurement-file.html)
diypass 5th November 2013 09:19 AM
any of you have measured the peerless tweeter BC25TG15-04
I need the file response measurement and impedance to import in my software
thanks
giralfino 5th November 2013 11:10 AM
If you can't find a frd file look here at page 9: http://audio.claub.net/Simple%20Loud...r%20Design.pdf
In any case keep in mind that a driver response is influenced by the baffle/box. I've done a measurement of this tweeter, but was in box connected to a crossover.
Ralf
Dissi 5th November 2013 12:05 PM
2 Attachment(s)
The tweeter is traded in Germany as Vifa HT250F/4. ASE formerly did publish a own datasheet and measurements. Note the top end of the on-axis response is quite optimistic.
diypass 5th November 2013 02:30 PM
Originally Posted by Dissi (http://www.diyaudio.com/forums/multi-way/245317-peerless-bc25tg15-04-measurement-file-post3691988.html#post3691988)
thank you very much dissi!!!
Resources saved on this page: MySQL 18.75%
