First ported cabinet questions.
Old 20th December 2003, 02:12 AM   #1
eStatic is offline eStatic  United States
eStatic's Avatar
Default First ported cabinet questions.
This is one of two front ambience cabinets I built. These were designed using a program I can't find nor its name remember. The 6" square at the bottom covers the port. The design parameters were selected to allow both ported and sealed modes. In the sealed mode, as is the one shown, they were paired with subs and xovered at 125 Hz One of those subs is shown in the left corner. I now need to remove the bottom covers, which are over PVC couplers. The lower mid must be removed, the port-tube passed throught the driver mounting hole and fitted into its port-tube coupler. Before final assembly I verified I could in fact insert and fit a port tube substantially longer than as calculated and still have minimum clearance in the back. Numerous issues now arise.
First is just seating and unseating the PVC pipe into its coupler. Done a lot of that in various contexts and I know that unless slathered with its solvent/cement it's difficult to seat all the way and can be even more difficult about releasing. This context is new to me. Perhaps there are tricks that can be used when it caries no substantial pressure. Huh, huh? I did search.
thanks
eStatic
This space for rent.
First ported cabinet questions.Hide this!Advertise here!
Help designing ported cabinet for dayton rss315ho saabracer23 Subwoofers 34 8th April 2008 09:52 AM
What creates the impedance peaks in ported cabinet? teemuk Multi-Way 1 26th February 2007 09:01 PM
Sealed Sub VS. Ported, questions about room gain... wigginjs Multi-Way 18 11th June 2004 09:07 AM
hello i'm new and big ol' cabinet questions ryangobie Multi-Way 3 28th March 2004 12:13 AM
stuffing in ported cabinet mike Multi-Way 1 25th December 2002 12:25 PM
Copyright ©1999-2017 diyAudio
