DUAL PURPOSE CABINET - diyAudio
Old 29th October 2013, 10:38 AM   #1
Default DUAL PURPOSE CABINET
Hi guys
Crazy question here. ..
I am wanting to build a 6.6 ft3 cabinet to house 2 Volt 2500.1 mid.bass drivers and tune the cabinet as low as humanly possible for when it is running on its own and then when I turn on the 18 inch Auras I will cut the drivers off at 50hz.
Can the cabinet be utilized this way.
My point is that I will run this cabinet solo cut at 380hz/3800 with my ATC mid n SS 7100
Sometimes and other times with subs..
Thoughts
thanks John
Old 29th October 2013, 11:01 AM   #2
sreten is online now sreten  United Kingdom
That box is way too big for two of those Volt drivers.
Maximum is 2.5cft for two tuned to 22Hz IMO.
They will need some EQ to combat the bass droop
due to using low Qts drivers in boxes around the
total Vas of the drivers. Bigger boxes don't help.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 29th October 2013, 01:59 PM   #3
Hi Sreten
Thanks for the info.
I appreciate your help
John
thanks John
Old 11th November 2013, 02:54 PM   #4
zead is offline zead  United States
was those the bass units or bass midrange volts
Old 11th November 2013, 07:32 PM   #5
Bass midrange.
thanks John
dual purpose Toroidal for LM3875/LM3886 JonGain Chip Amps 10 28th March 2013 11:22 AM
dual purpose amp and speakers heavyhanded Everything Else 1 16th August 2012 07:21 PM
A general purpose cabinet for trying designs? river251 Multi-Way 5 15th April 2012 05:39 PM
Multiple purpose dual regulated psu cviller Power Supplies 13 26th February 2008 06:03 AM
cabinet suggestions for dual 15" jbl woofers djquick_silver Multi-Way 4 24th September 2002 06:56 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
