Old 19th December 2003, 10:49 AM   #1
mounier is offline mounier  France
Default vintage Philips loudspeakers
Hello,
I have a pair of Philips "MFB Electronic 22 RH 532" speakers, housing built-in amplifiers - a free gift from my in-laws, who bought them 30 years ago...
The tweeters & médiums are dead. Philips does not seem to be able to replace them. I just called Philips France, to learn that they no longer make loudspeakers : Marantz provides them...
Does anyone know whether these tweeters & médiums are still available ; or, more probably, what are equivalent models can be used as replacements?
References :
• tweeters 2,5 cm AD 0160T
• médiums 12 cm , AD 5060 Sq
(output 20 watts)
What would you recommend ?
Thanks !
Eric Mounier
(who never throws anything away)
Old 19th December 2003, 05:07 PM   #2
http://www.mfbfreaks.com/ENG/index1.html
you could try contacting them, the forum is in Dutch though
Number of speakers : 3
Low unit : AD 8065 /MFB
Mid unit : AD 5060 /Sq8
High unit : AD 0160 /T8
Number of amps : 2
Low amp power : 40 W
Mid/high amp power : 20 W
Output capacitor amp :yes
Cross-over : 500 Hz (active) + 3500 Hz (passive)
Year of birth : 1974
Remarks : Very first MFB based system.
Replacing the tweeter is straight forward, the mid may be difficult.
Does the mid have a closed back ? or its own enclosure ?
Does the passive crossover contain any resistors ?
You sure the mid/high amplifiers work ?
Are all drivers open circuit ?
sreten.
Old 19th December 2003, 05:20 PM   #3
frugal-phile(tm)
planet10's Avatar
Default Re: vintage Philips loudspeakers
I just picked up a mismatched pair of these last weekend (i've seen at least 3 flavours) but run across them fairly often. (ie a matched set siting boxed up ready to ship to a client)
The 5060 is used as a very small bandwidth filler driver and is essentially a 5" whizzerless FR/midbass in a small plastic enclosure. I may have a set of these sans enclosure (with a different designation)
These were very common DIY items over here in the 70s so should be fairly common and "relatively" easy to scare up used. Some patience may be required.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th December 2003, 11:31 AM   #4
Thanks very much for these informations & advices. If anyone of you has one of these drivers, I am ready to buy them at a reasonable price.
Eric Mounier
Old 16th January 2004, 03:07 PM   #5
Hello!
The SQ-5060 is out of production but replacemnent SQ-50600 can still be found at some speaker stores, dont know if it is still in production.
Look at www.hifikit.se for instance
Use the search function and type in "philips"
You will see the 50600 and a copy of AD0163.
The AD0163 is, as I understand, the third generation of AD0160.
I hope this can be of some help to you.
Best regards
Martin Dellstig
Old 1st May 2008, 02:56 AM   #6
If you are still looking for these, I know of a guy that has a handfull left. They are the 4 ohm version though. Octagonal shape, plastic basket. Model # AD 5060/SQ4. NIB.
Old 14th December 2009, 12:36 AM   #7
I have a limited supply of AD 5060; AD 8060/W8; AD8065/W8; AD8066/W8 etc available for sale. If there is an interest, I may be contacted at tracer740@rcn.com
Sound is what is happening wherever there are ears to perceive
Music soothes the savage breast. ...
Vintage Philips CD Player CD560 DreadPirate Digital Source 7 11th August 2009 10:16 AM
Remagnetizing vintage loudspeakers montreal Multi-Way 0 17th November 2008 09:35 PM
Peerless JAPAN vintage loudspeakers aHobbit Full Range 0 30th November 2005 05:40 AM
Vintage Philips Kino Speaker tgroendahl Full Range 6 11th May 2005 09:40 AM
Info on vintage Peerless and Philips drivers? Dirk Multi-Way 1 2nd December 2003 11:25 AM
Page generated in 0.10453 seconds (73.85% PHP - 26.15% MySQL) with 11 queries
