Possible Cornscala Problem? - diyAudio
Old 22nd October 2013, 11:16 AM   #1
cradeldorf's Avatar
Default Possible Cornscala Problem?
Hi Guys, I bought a pair of Cornscala D's About a month ago and I personally thought they sounded like crap. I have been fiddling with them ever since. I think I might have found something that might be causing the horrid sound but I thought I'd ask you guys to see what you think? The other day I stumbled upon the fact that a magnet sticks real good to the screws on the terminal strips. Tonight I decided to do some more investigating to see if the buss bars in the terminal strips were also steel. They were not but I did find that the strips leading from the connection terminals to the wires running to the crossover are also steel. Would this cause the sound to be crappy? I'm pretty sure I've read in forums that running your signal through steel is a very bad idea. So what's your take on it? I've include a picture for your reference.
Old 22nd October 2013, 12:59 PM   #2
fpitas is offline fpitas  United States
I doubt that's it, I've never had trouble with those. Have you tried measuring the frequency response? Just a simple on-axis measurement would tell you if everything's hooked up right, and in the correct polarity etc.
Old 23rd October 2013, 01:21 AM   #3
cradeldorf's Avatar
I hesitate to say it's 1 million times better but now that all steel has been removed they sound like they should, It was a night and day difference. They sound like Klipsch's now.
Old 23rd October 2013, 12:30 PM   #4
Glad it worked out for you, enjoy
Old 24th October 2013, 06:30 AM   #5
cradeldorf's Avatar
Thanks Fpitas, I'm very happy with them now. Now that the Klipsch forum is back up and running I took the info over there because it's a more appropriate place for it.
Old 24th October 2013, 05:44 PM   #6
The steel was not the problem, the bi-metallic corrosion you eliminated was.
Cornscala Build TinTurtle Multi-Way 22 20th August 2013 06:45 AM
my rebuilt cornscala's totalcomfort Multi-Way 0 18th May 2013 05:16 AM
Any Cornscala builders here? cyto Full Range 4 2nd August 2012 08:59 AM
Cornscala II dworthington59 Swap Meet 2 3rd June 2011 10:39 PM
Split Cornscala minhaj Multi-Way 0 2nd March 2011 05:21 AM
Copyright 1999-2017 diyAudio
