The Darbari: new speaker project - diyAudio
Old 22nd October 2013, 03:55 AM   #1
tcpip is offline tcpip  India
Default The Darbari: new speaker project
Hi all,
Am starting a new project, and would welcome comments.
My initial thoughts on the Darbari are on this page.
After the Asawaris, am hoping that this will be a system I can live with for my own use (all the Asawaris have gone to friends).
This will be a three-way with Dayton RS woofer and mid, and Seas TBFC/G tweeter. Drivers were bought a few years ago. Enclosure building will start soon. Crossover has been ordered. And in case you are wondering how the hell does one order a crossover before even the enclosures have been built, please read the attachments.
Wish me luck.
Old 22nd October 2013, 01:42 PM   #2
picowallspeaker's Avatar
Well, good luck !!
There are some ( most of them ) faults in the reasoning that I found while reading the darbari project. I start from the bottom : the 6" will have an equalization like LT ?? Why ? (I would scale all the dimensions : 6 " woofer; 4" midrange and 3/4- 1" tweeter ); cone papers are floppy ? Why ? You're meaning that the cone doesn't follow the VC pistonic movement and changes in dispersion are uneven because only the very center emits the higher frequencies ? Well, paper is a very old material and of course there are better ones, but for other reasons (!?!).
The reasoning at the beginning about the reproduction of the voice might be true, but also slopes of the various drivers must be considered, e.g. 80 Hz Fc having 6 dB/oct slope would still play till 300 Hz (!?). Talking about vibrations and the way to confine them to inaudible levels, the only effective one is the one I exposed in the 'floating speaker enclosure' Thread
Old 23rd October 2013, 07:48 AM   #3
If a driver is put in a sealed enclosure, you don't know exactly how it will behave at the bottom end of its SPL curve, and what its F3 and Q will be. One either calculates this by box modelling and accurate sizing of box to get the desired Q and F3, or one designs an approximate box size and then uses LT to get the desired Q and F3. I am doing the latter. Nothing very revolutionary there.
After the 6" driver is fitted to the enclosure, I will take impedance measurements and get the "natural" Q and F3 of the driver in the enclosure. I will then plug these into the LT to get a Q of 0.7 and the F3 I want (I will probably go for 100Hz). This will give me a 2nd order high-pass at 100Hz. I will then add another 2nd order highpass at the same F3 to get a 4th order rolloff. As I said, nothing revolutionary here.
I think paper cones have higher second-order harmonics because they are not stiff and pistonic as much as hard metal cones. The fact that most paper cone drivers have higher low-order harmonics is quite well known, I believe.
Absolutely right. To address this, I intend to do 4th order acoustic for most of the slopes, if not steeper. This will minimise those problems, I feel.
In general, I don't know how people build first-order crossovers unless they are using full-range drivers. I much prefer higher-order unless I have a good reason to use lower-order slopes.
Yes, I guess such approaches are really excellent, but I am trying to get to 90% of that level with 20% of the effort.
Old 23rd October 2013, 11:56 AM   #4
Dissi is offline Dissi  Switzerland
You know what you are doing and I wish you luck with your 3-way project. Just a little thing to consider. Maximum excursion of the drivers limits the low frequency extension of woofer and midrange. Thus 25 Hz and 100 Hz seems to be a little optimistic, I would rather expect 40 Hz and 200 Hz. However that's still fine IMO.
Old 23rd October 2013, 03:28 PM   #5
You're probably right, but the question really is about the limits at a given SPL, isn't it? I may not have problems reaching low frequency levels at 5W and 10W power outputs, where I will listen at home.
Old 7th November 2013, 02:17 AM   #6
The building of enclosures has started. The woofer enclosure has good bracing, built as a separate assembly out of 20mm plywood, and inserted into the enclosures. The side walls will be clamped tightly to the bracing using screws and Araldite.
You can see some images of bracing here. These things are pretty impressive to look at, being about three feet tall.
Old 23rd November 2013, 03:09 AM   #7
Default Woofer box construction
The woofer enclosures are turning out well.
Click the image to open in full size. Click the image to open in full size.
The front baffle is being constructed out of three sheets. I am chamfering each sheet so that the cutout for the driver widens inside the box, creating as little reflections of the back wave as possible. (I guess this will be a much bigger issue for the midrange driver than for this one, since this one will have a a high-pass at 100-150Hz.)
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
More details on my page here.
Old 23rd November 2013, 03:17 AM   #8
Default The amplifier side of things
Am aiming to use Panson Audio's compact amplifier module for my six channels of amplification. LME49811-based modules with one pair of ThermalTrak OPS devices per channel. Am hoping they will serve this application well. They are a bit underpowered for my taste -- would have loved it if they just had two pairs of OPS devices instead of one, but then I have to make do with what I am getting.
I will also be adding speaker protection and amplifier soft-start modules to the amplifiers. I am thinking of making two chassis, with four amplifier channels in each chassis. (I need three per side; the fourth will be free for now.)
When the left channel and the right channel have completely separate circuits, can one call them "dual mono", even if three amp channels share a common transformer?
Old 8th January 2014, 06:41 PM   #9
The enclosures are almost ready.
I have yet to start work on the amplifiers. Am getting a new measurement mic (calibrated Dayton Audio mic) from Cross Spectrum Labs, and a new Behringer 302USB, for SPL measurements. Let's see how they work out. Am sure I will have to suffer a lot of pain figuring out how to configure this stack -- my old mic and USB sound card worked well but did not support XLR mic inputs, so could not use it with any of the calibrated mics available.
More details of construction on this page
Old 17th August 2014, 03:34 AM   #10
The enclosures are ready. Need to start fitting the drivers now.
My carpenter disappeared a few months ago, and it took me these months to find another one who would be good enough to work on these things. I also managed to locate a good polishing guy, but he was on holiday at his native village and returned only at the end of June. He's done a good job of polishing and finishing the enclosures -- PU glossy, with five to six coats of sealer. All this took time, while I twiddled my thumbs.
The stack of two enclosures is about five and a half feet tall. I am planning to get a wedge-shaped piece made to put between the two, to make the top enclosure point downwards a few degrees.
I have postponed my plans to build my own amplification. I have acquired a Marantz SR5200 AV amplifier instead, from eBay UK. It gives me six channels of amplification of adequate quality.
Miles to go still...
Help with speaker project davethomp Multi-Way 3 5th March 2009 12:18 AM
Speaker Project? strykr Full Range 0 12th April 2007 06:47 AM
my first speaker project (need help!) dyingemokids Instruments and Amps 5 15th April 2005 12:10 AM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
another 3 way speaker project... Al.M Multi-Way 1 25th October 2002 03:29 PM
Copyright 1999-2017 diyAudio
