Monster Massive
Monster Massive
Old 21st October 2013, 06:59 PM   #11
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by Juhazi View Post
The pathlength from tweeter -ceiling-ear is the same with tilt or without. Tilting reduces floor reflections effectively (larger angle) but sidewall reflections are almost same. The relative proprotions of reflections from different surfaces changes.
Floor bounce is often the most annoying and it's cancellation F is usually at range of 200-400Hz Floor/Ceiling Reflection Calculator
Generally I like the idea of tilted midrange horn!
The gradient midrange is a cardioid, so that definitely has an effect too.
Here's a funny story about cardioids:
I've raved a couple of times about how amazing some of the prosound sub setups are these days. For instance, Excision toured with PK Sound last year, and I've never heard bass like that in my life. But nearly every show that I've been to in 2013 has had the same crummy bass that I hate. Just a dull undefined roar, with no 'kick' and no 'slam.' The shows I've been to in 2013 just sounded like a bunch of mush.
Just a short list of shows with mushy bass:
1) Mad Decent Block Party
2) Datsik
3) Flux Pavillion
But last Friday I saw Placebo at the Wiltern, and *boom*, the show brought the bass! Tight, defined, slammin' bass.
And lo and behold, what did I notice on stage?
Yup, a cardioid array.
I'm starting to think that's what basically spells the difference between crummy bass and great bass is just use a cardioid. It's odd, because cardioid arrays seem to be semi-ignored by the diyaudio set.
Both Bassnectar and Placebo were using the same cardioid setup, with an array of subs in front, and a second array behind the first.
Like this:
How To......Cardioid Sub Arrays - Speakerplans.com Forums - Page 1
Old 22nd October 2013, 12:14 AM   #12
kenpeter is offline kenpeter  United States
Maybe you could get rid of diffraction at the midrange taps
by not having holes. Make the throat of foam or cardboard
with some bending mode radiators around the outside...
You said you were crossing with dsp anyway, so can you
blend the required mid delay without the phase shift of a
frustrum's cavity and taphole?
Old 22nd October 2013, 12:37 AM   #13
I am going to deal with diffraction from the midrange taps by filling everything with foam. I have 30ppi reticulated foam but I may try higher densities also. We have so much midrange power to burn, I don't think it would be crazy to use foam that's even higher density than 30ppi if necessary.
BMRs would probably work too though. I heard the Linn speaker at CES with a big BMR and it sounded fantastic.
Old 22nd October 2013, 08:01 PM   #14
JLH is offline JLH  United States
JLH's Avatar
Originally Posted by Patrick Bateman View Post
Here's a tentative summary of the frequency ranges, crossover slopes, drivers, etc
1) tweeter: Celestion CDX1-1425, 1500hz - 20khz
2) midrange: Dayton ND91 x 3, 180hz - 1500hz. This is the driver most likely to change, as I'm not sure if I can get them to cover a bandwidth that's this wide.
If you're going to use a mid with rubber surround, then you might want to look at the Faital 3FE25 in 16 ohms. Three of them can be wired in parallel and a 2.7 ohm series resistor can serve to bring them back to a nominal 8 ohms and give some attenuation to match the sensitivity of the compression driver. If you want to go bigger, then the 4FE35 is also available in 16 ohms.
FaitalPRO 3FE25 3" Professional Woofer 16 Ohm 294-1105
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 22nd October 2013, 08:02 PM   #15
JLH's Avatar
Since you are saying you want to use three mids, I'm guessing you are planning on a round horn with the mids mounted each at 120 degrees?
Old 22nd October 2013, 09:22 PM   #16
Regarding faital 3" drivers: the 4 ohm are superior EBP, sensitivity, No%..
I don't know why 16's are so much worse, I'm guessing dead weight of
excess coils outside the gap.
Patrick wants a silly high Q, and has his formula. But then complains
mids don't play high enough. I think time alignment should be in the
dsp crossover, and not by sandbagging mechanicals to make delay...
The 16ohm have higher Q and narrower EBP (given no cup on back
yet, they may not be all that different). but I think this is the wrong
direction to purposely go...
Old 22nd October 2013, 09:56 PM   #17
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Monster Massive
according to specs, the 16ohm is lighter, so I guess not the reason but Qts is much higher
btw, superior in what way ?
but sometimes specs may not be quite right, and unreliable
sometimes we know very little, and sometimes we know too much
Old 22nd October 2013, 10:23 PM   #18
I will be getting 4 of the 4ohm Neos for a different experiment.
We can see then if the published specs are accurate. But just
look to the half space efficiency, Q, EBP. And I ask you why
the 4 is so different from 16? In both the 3 and 4 inch series,
both the ferrite and neo. Makes mis-measurement of the spec
by Faital seem unlikely...
Old 22nd October 2013, 10:52 PM   #19
JLH's Avatar
Once you get those drivers on a Synergy horn, the EBP difference between them doesn't matter. Drivers with relative lower No% respond with higher horn gain over that of a higher No% driver. Saying there is a difference between the 4 ohm / 8 ohm / and 16 ohm model of the same driver would be like splitting hairs. Feel free to use what ever model gets you to the desired impedance. I prefer to wire drivers in a parallel when ever possible. You must always consider the effect of the other driver's Le on the response of the other drivers when you wire them in series. Sometimes it can help, sometimes it hurts you.
Old 23rd October 2013, 12:12 AM   #20
I am approximating the LeCleach curve by using square conical for the first half of the horn, mated to a monster roundover for the second half.
Here's how I'm doing it:
Jean Michel on LeCleac'h horns
The only reason I'm considering three drivers is because I'm not certain I can fit four.
Monster MassiveHide this!Advertise here!
Massive P3000.1 massive DC offset amc32 Car Audio 5 16th March 2011 05:40 PM
MASSIVE heatsinkS Krisfr Swap Meet 5 17th September 2010 05:59 AM
Massive D400x SS64 Car Audio 33 7th January 2010 02:11 AM
"Monster" Cable vs Monster Vintage MonsterVintage Everything Else 0 18th October 2004 11:35 PM
