Monster Massive
Monster Massive
Old 25th December 2013, 01:33 PM   #101
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
The serial cap is to reduce the peak and extend the bass and it does work. But that is for a box Q of 1.0-1.1
Old 26th December 2013, 08:32 PM   #102
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Ah, that makes sense. It would be hard to get the QTS that high, due to the very high BL and the relatively light cone and surround in the Summa.
For my current project, that might be worth looking into, as the specs are quite different. Here's a comparison of the woofer in the Summa versus the woofer I'm using in Monster Massive.
woofer: B&C 15TBX100 / Diyma R12
qms: 5.2 / 4.0
qes: 0.3 / 0.47
qts: 0.28 / 0.57
vas: 107.6L / 42L
fs: 35hz / 27.6hz
Old 27th December 2013, 03:56 PM   #103
mayhem13 is offline mayhem13  United States
Hey Patrick......ever consider 4 dome midranges for use in a synergy type system? The Dayton RS52 in quads woulds provide enough efficiency and could go as low as 500hz without strain. Just something to consider. It would be interesting to create a throat for the CD using the domes to form it.......could be similiar in function to JBL's new guides used in the M2. Being forced due to costs to work with fiberglass, epoxy and resins on my boat, ive been pretty impressed with what is possible with this stuff and some creative thinking.
Old 2nd January 2014, 11:14 PM   #104
Indeed! I have four of them here, and I gave them a try. They work well. There are only a couple of drawbacks:
1) they basically have no surround, so their excursion is virtually nil. This limits the SPL of the entire system, and also the dynamics.
2) I would personally recommend reducing the back chamber. You can do this by sawing the driver in half. (The chamber is plastic, which makes it easy to reduce.)
Once you reduce the back chamber, it increases the efficiency by narrowing the bandwidth of the driver. That helps offset the lack of SPL.
Having said all that, the ND91 has a lot in common with the RS52, but with more output:
1) The ND91 and the RS52 both have an aluminum dome that's similar in size
2) Both drivers have a copper shorting ring to reduce distortion
Old 30th January 2014, 03:24 AM   #105
The system is coming along nicely.
Probably the main goal for this project is to reduce the footprint of my reference speakers. (Gedlee Summas.) In order to get some bass, I'm using multiple subs, distribute throughout the room. Here's some pics of how it's coming along. There are currently three subwoofers:
1) A Kef vented sub that's up on my Ikea shelf (up on the top right.)
2) A bandpass sonotube sub, that's over in the opposite corner.
3) Possibly the most interesting sub is a dual 8" tapped horn, loosely based on the TH-Spud and Mike's Insubnia.
The tapped horn sits on the floor, and I have my chair on top of it. So it's basically a platform that I sit on. It's hidden in the corner, and hard to see I think. Nearly all of the electronics are built into the tapped horn; this includes the miniDSP, the sub amp, and the mid and high frequency amp.
Old 30th January 2014, 03:30 AM   #106
chrapladm is offline chrapladm  Australia
How big is the dual 8" And how low does it go?
Old 30th January 2014, 03:40 AM   #107
It's pretty big. About six and a half cubic feet.
It's designed to get loud, not low; I'd actually built it for my old Honda, with the intention of making a loud ol' horn for SPL type stuff. It's tuned at about 35hz, and the F3 is about the same.
But then I sold the car, so I moved the sub into my living room!
Details here: Tapped Horn for the Lazy and Impatient
Old 30th January 2014, 04:11 AM   #108
So this is the dual Type R Alpines yes?
I saw there were a few ideas you were contemplating. Also was curious how the 4.5" driver was going to play out. Maybe a dual 4.5" TH?
Old 11th February 2014, 07:50 PM   #109
Zvu is offline Zvu  Serbia
Sin Bin
Originally Posted by Patrick Bateman View Post
Ah, that makes sense. It would be hard to get the QTS that high, due to the very high BL and the relatively light cone and surround in the Summa...
Are you referring to 15TBX100 ? What is "relatively light" in B&C 15TBX100 ?
It has Mms=163gr. It has one of the heaviest moving systems i've seen in 15" pro woofer - if we count out dedicated subwoofers that can't do anything beyond 300-400Hz.
Old 11th February 2014, 08:01 PM   #110
I mostly do car audio. In the world of car audio, a 15" with a 163gr cone is "light."
I don't have the mms spec of my TC Sounds fifteens handy, but it sure *looks* heavier than the 15TBX100. Foam surround versus accordion surround, aluminum cone versus treated paper cone. I quick look at Parts Express shows an MMS of 383g for the LMS-R 15" woofer from TC.
Monster MassiveHide this!Advertise here!
Massive P3000.1 massive DC offset amc32 Car Audio 5 16th March 2011 06:40 PM
MASSIVE heatsinkS Krisfr Swap Meet 5 17th September 2010 06:59 AM
Massive D400x SS64 Car Audio 33 7th January 2010 03:11 AM
"Monster" Cable vs Monster Vintage MonsterVintage Everything Else 0 19th October 2004 12:35 AM
Copyright ©1999-2017 diyAudio
