Tangband W6-658 2 or 2.5way - what tweeter - diyAudio
Old 18th October 2013, 01:22 PM   #1
bcrazy is offline bcrazy  Norway
Default Tangband W6-658 2 or 2.5way - what tweeter
I have 4xTang Band W6-658i that i got at bargain price.
I want to either build a floor standing 2 way, or a floor standing 2.5 way. I will keep the volume around 35 liters the same either way so if i go 2.5 way it will not go as deep, but if 2way will probably go deeper. What will sound the best?
http://www.tb-speaker.com/detail/1208_03/w6-658i.htm
I have no tweeters yet, bu have looked at this vifa
Vifa DX25TG09-04 1" Fabric Dome Tweeter 264-1020
To keep it simple (and cheap) i was thinking to use a 1st order filter and cross over to the tweeter high.
Any suggestions?
Old 18th October 2013, 05:18 PM   #2
Looking at that inductance rise, I doubt a single component will do much for the woofer. I would anticipate a 2nd order filter at least. Maybe you can keep this design "in the family" so to speak, and use this tweeter:
https://www.parts-express.com/pe/sho...number=264-870
It's a pretty low distortion tweeter according to the guys who tested it on techtalk.
The Qts on those woofers is a little on the high side at .45, and likely to be a little higher in real life (and higher still with an inductor). Maybe the right thing to do is a sealed 35L 2.5 way. Do you have a sub?
Then again, what do I know?
Old 18th October 2013, 06:02 PM   #3
diyAudio Member RIP
In 35 litres a 2.5 way would be sealed, a 2 way vented.
rgds, sreten.
Old 18th October 2013, 10:54 PM   #4
No i do not have a sub. This will be a build just for fun. My daily speakers is a 2way with seas excel 6.5" and Scan-speak D2905/9500. This build is not meant to replace those.
Old 18th October 2013, 11:30 PM   #5
In that case, I would just build a sealed speaker and use up all the woofers. Should be enough bass for most music.
TangBand W6-1530S 6.5" coaxial grantnsw Full Range 11 12th May 2014 01:58 PM
FS: Two Tangband 6.5" subwoofers (W6-1139SG) skinnymonkey Swap Meet 9 6th November 2012 10:57 AM
F.A.S.T System Tangband W6-1108SA + W3-315E jockel77 Full Range 0 25th November 2011 12:41 PM
Wtb TangBand W6 1139SI sts9fan Swap Meet 0 28th November 2009 02:14 PM
Vas of TangBand W6-789S midbass drivers? tcpip Multi-Way 3 7th March 2006 04:41 AM
Copyright 1999-2017 diyAudio
