Old 18th December 2003, 02:08 AM   #1
cm961 is offline cm961  Canada
cm961's Avatar
Default 6 to 8 inch driver for studio monitors
Hi guys,
I hate to ask for driver selection advice, but I've been searching for days, and projected graphs based on skeptical speaker parameters are driving me insane.
The Project: I'm building a set of powered studio monitors to replace my current ones. They will be biamped and use gain clones (LM3886 for woofer, LM3875 for tweeter). I have already designed the circuit board, crossovers, power supply, mechanical layout, etc. (although I can alter the 24dB L-R crossover frequency to whatever). Oh and I might be pursuing (sp?) these as a commercial endevour (as in have a few hundred made) if it works out well.
I initially looked at the vifa P22WPs used in the mackie HR824 studio monitors availible for cheap at various places. They are a little less than $30 and they look really great. One problem though, they aren't shielded. I'm almost positive that shielded studio monitors are a must as more and more studios are using computers. My current set are unshielded and I have to keep them about 1-1/2 foot to 2 feet away from the screen, which can be a pain. So I started looking at shielded drivers. The Tang Band drivers look really great except for their low power handling, but they have a higher efficiency to compensate. In fact, they graph so well that I wonder if the parameters are a bit exagerated (sp?). Can anyone comment on this or recommened a good driver for around or less than $30 USD?
Thanks a lot!
Pete
P.S. I'll be more than happy to share my gainclone PCBoard layout as soon as its finished. It contains the power supply (except Xformer), crossovers, and two channels of gainclones (3886, 3875) on one 6"x4.1" board.
Old 18th December 2003, 03:43 AM   #2
GM is offline GM  United States
GM's Avatar
Not at that price. I would use two of the Mackie Vifas in a 1.5ft^3 bipole with the mags touching to make them complementary bucking magnets.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th December 2003, 04:55 AM   #3
Default Re: 6 to 8 inch driver for studio monitors
Originally posted by cm961
Hi guys,
Thanks a lot!
Pete
Well, I am running my HR 824s directly next to the monitors - no problems here - but then again, they are flat panels. Point is: I am not sure you really need to worry about the shielding at this point (or build it into the cabinets).
Check out the SEAS P21 etc. drivers - personally I am not fond of the VIFAs, I am ready to rip them out of the HR824s (along with the SEAS HF driver) and start over.
Cheers
Cheers
RB
Old 17th February 2004, 02:40 AM   #4
What ever happened to this project? I was looking into making an Alesis amp/Mackie hybrid just because the amp and woofer are cheap and I like the way the mackie sounds. However, I'm sure the Mackies are shielded...
DIY studio monitors? MikeHunt79 Multi-Way 29 16th July 2010 04:31 PM
Studio monitors w/ sub echosystm Full Range 1 14th June 2008 01:07 PM
studio monitors RyanC Multi-Way 26 29th April 2004 02:27 AM
monitors for studio DIY rafafredd Multi-Way 16 14th May 2003 11:06 PM
FS 604 8G Studio Monitors Thatch_Ear Swap Meet 1 6th August 2002 01:25 AM
Page generated in 0.09556 seconds (74.56% PHP - 25.44% MySQL) with 10 queries
