Old 18th December 2003, 01:01 AM   #1
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Default High Excursion 8 Inch Woofer. Is Their Such A Beast?
Looking to replace some foam rot 8 inch woofers with
high excursion 8 inch woofers.
The cabinets are;
19 inches tall
10.5 inches wide
7.5 inches deep
Power is not an issue, for I can feed them anywhere from
100 to 400 watts continuous per channel
Any suggestions and/or recomendations would be greatly
appreciated.
OMNIFEX
Old 18th December 2003, 01:05 AM   #2
This might be a guide.
The trick is in finding one.
http://www.diyaudio.com/forums/showt...436#post284436
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 18th December 2003, 01:11 AM   #3
michael is offline michael  Australia
Send a message via MSN to michael
Peerless 8" HDS woofers have 5.5mm of Xmxax, thats quite close to high excurtion as an 8" is going to get, i also think that the adire AV8 has a reasonable xmax and it also models very nicely, something i personally am a bit causious of.
Old 18th December 2003, 01:55 AM   #4
Try this, Steve says 4.9mm xmax
http://www.apexjr.com/SuperSub.htm
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 18th December 2003, 02:37 AM   #5
cm961 is offline cm961  Canada
cm961's Avatar
I've found a few...
There's the ApexJr Super 8 mentioned above...
There's the Adire AV8 mentioed above...
There's a Tang Band one that graphs really good for real cheap, of which, as mentioned above, can be a little skeptical.
Also, you could check out JL Audio 8W0, or 8W4 etc. I know they're good.
I believe the cheapest are probably the Tang Band and the ApexJr. Hard to judge how good they are without trying them.
Pete
Old 18th December 2003, 02:57 AM   #6
BAM is offline BAM
Send a message via AIM to BAM
Someone like John at Stryke Audio needs to start carrying the high-excursion 8" that TC-Sounds builds.
Old 18th December 2003, 03:35 AM   #7
exurbia is offline exurbia  Australia
exurbia's Avatar
Have you had a look at these ?
http://www.paudio-europe.com/product..._1_27_tm-8.htm
Old 18th December 2003, 03:39 AM   #8
exurbia's Avatar
Cannon sound, in OZ have the 12" version on sale, I wish i could justify buying a pair or two.
They might be just the thing for a dipole sub
Old 18th December 2003, 04:38 AM   #9
That PAudio TM-8 certainly looks like a great 8" woofer.
A mail order house in America sells the 10" and 12" version of it. The 12 inch is $420 and the 10 inch is $390. I think we see a pricing trend here....
-Anonymous
Old 18th December 2003, 04:46 AM   #10
Send a message via ICQ to ThingyNess
Very cheap, and quite high excursion is the TB W8-740c, found at www.nuera-acoustic.ca.
Inexpensive, and they ship out of both the US and Canada, so shipping isn't bad at all.
Their listed 12mm xmax is right on the money, being measured by the (vc height - airgap height) /2 method. Very good power handling, despite their low rating in the datasheet. I've personally pushed 200W RMS (brownish noise) through one for an hour or so with no ill effects.
I'd like to see a little better suspension travel out of them to go with the 12mm one-way xmag, but it's about as good as can be expected within the confines of a small 8" diameter basket and a smallish diameter spider. I'd estimate it at about 16mm or so. At any rate, an excellent performer for its size.
Karlson for high impact low excursion applications freddi Multi-Way 1 31st March 2007 05:51 AM
Any drawbacks to using ferrofluid in a low-excursion woofer? 454Casull Multi-Way 7 9th December 2006 04:40 PM
How linear is Cms for a high-excursion subwoofer? Oborous Subwoofers 17 31st October 2006 08:43 PM
where to buy 8" high excursion sub in EU ? wingman Subwoofers 25 12th June 2004 11:18 PM
high excursion drivers for sealed boxes pkgum Subwoofers 20 28th November 2001 08:07 PM
Page generated in 0.10974 seconds (77.59% PHP - 22.41% MySQL) with 11 queries
