Old 18th December 2003, 01:39 PM   #21
kevyjo is offline kevyjo  United States
For what it is worth, I had excellent luck with apexjr. you get two for $70, seems very resonable to me.
Old 20th December 2003, 04:52 AM   #22
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
ThingyNess
I may have to go for the W8 740C's.
Apparently, TC Speakers sell only in quantity.
50 speakers minimum!!!
OMNIFEX
Old 20th December 2003, 06:21 AM   #23
RAW is offline RAW  Canada
Go for the TB i have them in ported 1cft cabinets tuned in the 30hz range and they will take a 150 plate amp with boost added in around 25db
I showed one off at my NW DIY event I held and it impressed those who seen it.
Good luck Al
Old 20th December 2003, 07:01 AM   #24
Send a message via ICQ to ThingyNess
Oh, and for what it's worth, the TB doesn't have a copper faraday in its motor structure, or any other fancy features, but it does have a hyperextended pole piece (extends above the top plate), and should have a relatively symmetrical BL vs. X curve.
It's tough to beat for the price.
Old 20th December 2003, 01:20 PM   #25
Thingyness:
Thank you for that information. That is very important. That extended pole piece makes it a symmetrical field, which means that the woofer will not exhibit "suck-in" in a ported box near resonance.
I consider that a "fancy feature", lol. Fancy enought to get the job done, anyway.
Actually, except for Peerless, most subwoofers that do have a symmetrical field achieve it by extending the pole piece instead of using the Faraday ring.
Whatever, either method will do. The extended pole piece is good news. I would not recommend making a ported box with any driver that does not have a symmetrical magnetic field, which is usually achieved either through an extended pole piece or a shorting, (Faraday) ring. This Tangband has it.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 21st December 2003, 01:16 AM   #26
paulspencer's Avatar
I was impressed initially with the 8" TB sub. But it didn't model well at all. It didn't get near xmax within its stated thermal limits in a vented box and it had a strange response. Below 100 Hz it dropped off very early and had a drooping response different to any sub I have seen. In fact, it looked as if it would need some filtering to get a reasonable response. To be honest I had written it off as a cheap and dodgy driver, perhaps I shouldn't have. Those who have used it, how did you find it's response and power handling - did you actually manage to use its excursion limits?
I had initially thought it could work as a small vented sub with a HT setup with 3" or 4" TB cubes. A nice budget HT system.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 21st December 2003, 03:22 AM   #27
I too had got the testing on the 12" cube last year.And once thought these would only work with a high excurion PR like the one Bob at CSS brought in for them.
But after building a few test cabinets they are very very happy in the 1cft cabinet ported.
They do need the boost in at 25hz from my first tests
I will get responces up after a little revamp of the DIY site.
But the MCM copy just lost its suspension after a few months of use.
Karlson for high impact low excursion applications freddi Multi-Way 1 31st March 2007 04:51 AM
Any drawbacks to using ferrofluid in a low-excursion woofer? 454Casull Multi-Way 7 9th December 2006 03:40 PM
How linear is Cms for a high-excursion subwoofer? Oborous Subwoofers 17 31st October 2006 07:43 PM
where to buy 8" high excursion sub in EU ? wingman Subwoofers 25 12th June 2004 10:18 PM
high excursion drivers for sealed boxes pkgum Subwoofers 20 28th November 2001 07:07 PM
Page generated in 0.09726 seconds (69.53% PHP - 30.47% MySQL) with 11 queries
