Crossover DCR question - diyAudio
Old 10th October 2013, 09:55 PM   #1
cradeldorf's Avatar
Default Crossover DCR question
On a 2nd order crossover..or any order larger than 1st, Should the woofer dcr + the woofer inductor dcr added together equal the HF driver dcr + the HF inductor dcr added together?
Old 11th October 2013, 01:27 AM   #2
no, woofer and tweeter crossover are separate networks, and need to be calculated separately
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 11th October 2013, 06:32 AM   #3
cradeldorf's Avatar
But what about electricity will always follow the path of least resistance?
Old 11th October 2013, 09:12 AM   #4
cradeldorf's Avatar
Did some in depth reading tonight about it. I think I got my answers. Thanks for the help Pete.
Crossover Inductor DCR Values and General Crossover Advice Wayniac Multi-Way 6 15th December 2012 03:59 AM
DCR difference. jayam000 Subwoofers 5 17th November 2010 04:33 AM
Crossover DCR issue zaffle Multi-Way 5 25th November 2009 03:06 PM
Tube rectified LC PS for 6SN7 Aikido - choke DCR question LowRedMoon Tubes / Valves 3 20th June 2008 06:20 AM
Crossover inductor DCR value vilts Multi-Way 3 1st July 2005 08:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
