Floor-to-ceiling array vs CBT
Old 10th October 2013, 03:35 PM   #11
Budgie is offline Budgie  United States
I am very happy with the performance of my floor to ceiling line array, but I haven't listened to a CBT array yet. I believe the CBT design ignores the problem of ceiling reflections, were a full line does not.
Old 10th October 2013, 04:02 PM   #12
Generic George is offline Generic George  United States
Actually if I understand things correctly (and I may not), it makes better use of them and is part of the reason for the characteristic curve and the power shading on the drivers as they curve. They aren't designed like they are simply because of someone's pet hobby horse as to what makes for good sound reproduction, there does appear to be quite a bit of research and experimentation behind them.
http://www.parts-express.com/cbt36/#
Originally Posted by PartsExpress
Specifically Designed to Eliminate the Detrimental Effects of Floor Reflections
The CBT36 has been specifically designed to operate over a reflective ground plane and does not suffer from destructive floor-bounce effects. The curved line array of 72 tweeters extends all the way down to the floor to take advantage of the ground-plane acoustic reflection. Effectively the floor provides a reflective surface that acoustically extends the array below floor level and thus creates an array that is over 10 feet tall and controls vertical coverage and directivity down to below 160 Hz!
The Vertical and Horizontal Coverage of the CBT36 Greatly Reduces Ceiling and Wall Reflections
The above-the-floor vertical coverage of the CBT36 is a narrow 28° which is extremely stable with frequency. This greatly reduces ceiling reflections as compared to a typical box style system. In addition, the horizontal coverage which is very broad narrows as you go around the side of the system, which also significantly minimizes side wall reflections.
Old 10th October 2013, 05:33 PM   #13
Juhazi is online now Juhazi  Finland
Juhazi's Avatar
A domestic line array or cbt speakers concentrate on vertical directivity but mostly they completely disregard the principles of even horizontal directivity! I simply just don't like the hype around them... First of all, we have our ears placed horizontally for stereophonic localization, we walk - don't fly etc.
Here is horizontal 0¤ vs 30¤ of the Selah Audio CBT lindked above. 6dB dip around 2kHz at 30¤ is really really bad! And the speaker is not symmetrical - I suppose this is the better side!
It would be so simple to make these better, it is so hard for me to understand this dilemma. But I don't want this kind of poles in my room... I just keep on nagging about this
AINOgradient speaker project
Old 10th October 2013, 06:34 PM   #14
Speakers are inherently flawed devices and that's even before you drop them into a room which is never designed with audio reproduction in mind (Would you want to live in an anechoic chamber?). There are going to be trade offs, compromises, advantages and disadvantages to any set up no matter how much money you spend or how they are designed.
How is it you think they could be made better?
Old 10th October 2013, 06:59 PM   #15
What speaker has "even horizontal directivity!"? And at what frequencies? Don't all speakers will become directional at some point, and many highly regarded speakers have narrow radiation patterns, both vertically and horizontally. Electrostatics and planers for example.
Old 10th October 2013, 07:08 PM   #16
Well at least according to the marketing information the CBTs are. Have you read any of the technical papers on them?
I believe the SEOS/Gedde style speakers are supposed to as well.
Though they are certainly NOT going to appeal to anyone who cares about how the speaker looks.
This is out of my area of expertise though.
Old 10th October 2013, 10:59 PM   #17
jeno is offline jeno  Norway
The vertical problems are the same when placing drivers side by side whether it is a CBT or straight array. The trick is to get the crossover point as low as possible and the mids as close to the tweeter as possible. It can be done, but that's not the topic of this thread.
I am interested in vertical polars of a floor to ceiling line array. Does anyone have them?
Old 11th October 2013, 12:40 AM   #18
dumptruck is offline dumptruck  United States
I'm not sure I've ever even seen a photograph of a true floor-to-ceiling array, now that I think about it, let alone polar measurements.
Old 11th October 2013, 08:33 PM   #19
The full height line arrays may be more rare than I new. People talk about them from time to time, but it seems to be mostly theory.
Maybe I will make a quick and dirty prototype with cheap full rangers to have a look at the performance from the mid range and down. We know the upper range from straight arrays will be good from Keele's simulations. It would be interesting to see where in frequency vertical control is lost with an array coupled to a reflecting floor and ceiling, if it would be lost at all.
Old 11th October 2013, 08:37 PM   #20
I meant of course horizontal problems.
Floor-to-ceiling array vs CBTHide this!Advertise here!
Alpair 7 used for Keele CBT Array HiroPro Full Range 9 11th March 2016 11:25 AM
Building some CBT clones ... rhubarb9999 Multi-Way 26 11th September 2013 03:30 AM
Driver at floor level or ceiling?? Moondog55 Subwoofers 21 15th April 2012 12:34 PM
Floor to Ceiling ESL ? Borat Planars & Exotics 26 12th February 2010 01:11 AM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
