my current enclosure allows the different configurations.
sealed 1)ports blocked -> red vented 2)both ports open -> green (tuned @32.5 hz) 3)one port blocked, the other open -> yellow (tuned @ 23 hz) attached are gain and group delay charts from winisd (the white line is a shiva in 3.88 cu. ft sealed box for .6 qtc) basically, my question is which config would be my best choice for sq and which for deep bass? |
#2 |
group delay...
#3 |
i think that having both ports open gives you by dar the best seat rumbling bass for movies and some electronic music, this may sound great with other music as well, it depends on the woofer, but what you are doing is great, leaving options, good work
build it and then use it open ported and listen to movies and music see what you think, then listen to the same music and movies with it sealed and also half open. you be the judge of what you like most, but the dual open ports will definately give you the most HT bass good luck regards michael |
#4 |
There's no question that the green alignment will
appear to have the most bass and power handling. The other factors are placement of the sub and your room gain, basically your room size. One alignment may suit your room better than the others, if its the sealed box, you will get tight clean bass. But as you can see efficiency in the low bass is not good. If its the 23Hz tuning, it will be able to produce a lot more really low bass than the sealed box. So you really have to try them all. Possibly the ideal is four ports, two giving you 23Hz,and four giving you 32.5Hz, so three gives you another intermediate alignment. Or 3 ports for 32.5Hz, with the option of two. |
| i need more help with ports than GW | asoprs | Multi-Way | 7 | 6th March 2006 11:01 PM |
| Ports - Where to buy? | pow216 | Subwoofers | 6 | 31st March 2005 03:34 AM |
| help on ports | sidd_raj2002 | Subwoofers | 3 | 17th January 2005 10:48 AM |
| Need some help regarding these ports | Xristo | Multi-Way | 2 | 5th November 2004 09:24 PM |
| curved ports vs. multiple ports | Craig | Multi-Way | 1 | 22nd September 2002 07:30 AM |
| Page generated in 0.08929 seconds (73.49% PHP - 26.51% MySQL) with 11 queries |
