Help - My Speakers Are Too Small
Old 25th October 2013, 11:46 PM   #51
ODougbo is offline ODougbo  United States
Now's there's a large cap on the tweeter; a MS design uses a 9.uF in a 4" mtm (Vifa XT25).
Strange that cap is 2.5 x larger in the d'Appolito design 8.2uF vs. 3.3uF in the 2-way.
There is a replacement woofer for the Troels Grovsen designs - I'll have to look for old email with details.
Edit - sorry no, it was a different project:http://www.troelsgravesen.dk/Peerless_HDS830875.htm
Old 27th October 2013, 11:09 AM   #52
Need one more of these, # 5
Getting faster, but still several hours of work, which is fine AND its going to warm up later for painting
I want to keep xo costs down; diy 18g solder spool coil e.g.
Q. If I use the 4.7cap, I'm guessing I can replace the 15uF with a 10uf?
Also, since we are experimenting with these, can the xo be brought down a bit?
I could just replace the 4.7cap; willy-nilly with slightly larger ones but worried about phase.
Old 27th October 2013, 11:39 AM   #53
Dissi is offline Dissi  Switzerland
18 awg woofer coil and 4.7/10 uF on the tweeter? Still good, try it.
Old 27th October 2013, 12:47 PM   #54
A minimum crossover saves two coils.
Note: 10 uF instead of 15 uF is a bad idea here and the frequency response is as good as it gets...
Old 27th October 2013, 12:50 PM   #55
Well that's interesting and in the nick of time....
Thanks Dissi!!
Old 27th October 2013, 05:03 PM   #56
Could be trouble....they may work better!
Hard to say really, but these are a bit brighter......
I like them
Made up pair - 16uf tweeter caps, btw.
Nope we didn't save much
Old 27th October 2013, 05:14 PM   #57
You never know. Anything from "much worse" to "even better" is possible. I'm only guessing, you decide.
Old 28th October 2013, 10:17 AM   #58
The box in pic above is the set that had the tweeter break-up. This is gone now, so that's an eye opener
Maybe some of the x25's work better than others, which was the case with MDT 28-30's; some had "the noise" others were crystal clear.
This xo version is well balanced, maybe gave up some bass, but hard to say - still plenty. The middle is shinning through; very pleasant and sound wayyyyy better than ever expected.
Old 1st November 2013, 03:36 PM   #59
Default Little rumble boxes
These are a blast! And learned a few things along the way.
e.g. the jumbo woofer coils didn't do much, the smaller ones worked fine.
Dissi, make sure you are sitting down - Raised the tweeter level this time; 3.3ohm. Really like what you did with the tweeters, very natural
The black one on the floor won't be here long, that's going to friends for a swap
Old 6th December 2013, 06:29 AM   #60
caz001 is offline caz001
Default Peerless 832591
Hi ODougbo,
I have just tried to PM regarding the two projects you completed using the Peerless 832591. I have four brand new one sitting in my garage along with two Peerless 811827 that I was going to use in an MTM configuration. I've also read through your other posts where you used the 832591 with the XT25 in a smaller bookshelf design.
I would like to contact you if that's ok just regarding some questions I had.
Cheers
Caz
Help - My Speakers Are Too SmallHide this!Advertise here!
Speakers for small bedroom??? Studio Monitors vs Computer Speakers? matthughes64 Full Range 4 16th May 2011 11:32 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 09:36 PM
Small speakers for a small tube amp jeppix Full Range 17 29th January 2010 09:10 AM
Small Speakers 4' Krisfr Parts 11 7th September 2009 01:44 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 02:19 PM
