Supravox 215 vs PHL 2540
Old 28th September 2013, 08:50 PM   #11
Eldam is offline Eldam  France
Banned
Originally Posted by stasgrigorev View Post
What do you want to say about Supravox, I do not quite understand.
cONCISTENCY building problem. The 13 cm is very good not only with measure but with real life hearing !
Qts under 0.4 is not ideal for closed box but you can have a closed box with such speakers..
Old 28th September 2013, 08:55 PM   #12
stasgrigorev is offline stasgrigorev
And efficiency is not enough
I`m need 95+ db
Old 28th September 2013, 09:02 PM   #13
What about VOLT Ps8/151M ?
Old 29th September 2013, 03:55 AM   #14
murphythecat8 is offline murphythecat8  Canada
look at audax pr170mo, best mid ive heard by far. 98 db, a real world class mid.
Old 29th September 2013, 09:29 AM   #15
Banned
Hi MurphyThe Cat,
And not expensive for the quality. Good sound reputation.
Nearer to the Supravox for the non coated paper, nearer to the PHL for the non wide band aspect.
Fs could be problematic. Murphy use 400 hz if I remember.
Old 29th September 2013, 09:33 AM   #16
Well, so turns out that the there are practically no choice and no alternative Supravox?
Old 29th September 2013, 09:37 AM   #17
http://www.haut-parleurs.fr/fiches/audax/pr170m0b.jpg
Old 29th September 2013, 09:47 AM   #18
http://www.audax-speaker.de/index.ph...articles&index[shop_articles][action]=details&index[shop_articles][category]=8&index[shop_articles][data][shop_articles_id]=29
Old 29th September 2013, 06:50 PM   #19
Yeah in my setup, in a 40 L, the audax rolls off around 375 hz. I run them as high as 6khz with no problem.
Old 29th September 2013, 06:57 PM   #20
ScottG is offline ScottG  United States
This graph is a lot more honest, and even it doesn't show the problems with the surround at 1.4 kHz:
(..note that the coated (nextel) version of this driver will help smooth out the upper band ripple, part #PR170N0).
perspective is everything
Supravox 215 vs PHL 2540Hide this!Advertise here!
Supravox 215 Signature nirvana Swap Meet 1 10th February 2013 07:44 AM
Ongaku 211 and Supravox 215 Angel Puerto Tubes / Valves 10 24th January 2013 03:35 PM
Supravox 215 and backhorns jsb Full Range 11 15th June 2007 05:47 PM
Supravox 215 Signature Bicone Angel Puerto Full Range 3 24th July 2005 03:03 AM
supravox 215 bicone JamesD Full Range 5 29th April 2005 02:02 AM
