passive radiators for midrange
Old 6th October 2013, 10:40 AM   #21
Cousin Billy is offline Cousin Billy  Canada
sreten
I am using the Accuton C158 8 085 midrange.
When I was listening to the 2-way section, I fell in love with the openness of the sound. When I added the capacitor for the high pass, something happened. That cleanliness, or openness of the sound was subdued. I have on hand Duelund CAST PIO's, Duelund VSF's, Mundorf Silver/gold/ oil, and even more.
It didn't matter which cap I introduced, or which combination of caps, that sound which I loved was gone.
Adding the notch may be the wrong way of doing it, but it sounded better to my ears.
I have no empirical data, just the smile on my face.
Old 6th October 2013, 12:05 PM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Cousin Billy View Post
Tinitus
Please help. Where would my phase problem come from?.
my guess is it's primarily caused by the sidemounted woofer
sometimes we know very little, and sometimes we know too much
Old 6th October 2013, 12:52 PM   #23
Tinitus, you have hit the nail on the head. Yes, the side firing woofers are my last obstacle.
The natural rolloff of the midrange, coupled with the high pass notch, gives me a steep drop starting at 120Hz.
My testing now involves inverting the signal from the woofers, and adjusting delay. This is proving to be the longest to solve problem, but the DSP helps.
In the future I might try facing the woofers forward, though this will make for a very wide speaker.
Old 6th October 2013, 01:31 PM   #24
On Hiatus
SY's Avatar
What is your crossover point between the woofer and midrange? What are the frequency responses of each without the crossover? Have you measured the driver/box impedances?
I think that the side mounting issue is a red herring- your real problem is the first order crossovers, which are extremely unlikely to give you a 6dB/octave acoustic transfer function- and are HIGHLY sensitive to physical offset. Your focus on the capacitor brands suggests that you haven't really looked at the fundamentals here. and that's likely where your problem is.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th October 2013, 02:57 PM   #25
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by head_unit View Post
I have only ever seen Electro-Voice implement a vented mid-range
CV was another. 15" 3 way with a 10" vented mid.
planet10 needs your help:
Let's help Ruth and Dave
Old 6th October 2013, 06:08 PM   #26
Originally Posted by SY View Post
I think that the side mounting issue is a red herring ...
no problem if crossed low, and active
but with a midrange rolling off at 100hz by itself ...
adding a cap, and it might start rolling off much higher
and further, at ressonance it might also cause a bump
as described, it worked better without any crossover on midrange
Old 6th October 2013, 07:12 PM   #27
GM is offline GM  United States
GM's Avatar
Altec's 6041 studio monitor 'mid' is a vented 604 :
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th October 2013, 07:42 PM   #28
GM
is it a 2.5way ?
Old 6th October 2013, 08:52 PM   #29
GM's Avatar
No, discrete 3 way.
GM
Old 6th October 2013, 09:07 PM   #30
big driver in small vented box ?
I suppose it gives some 'midbass gain, and they thought it sounded better that way
early BSC compensation ?
when was this speaker designed ?
passive radiators for midrangeHide this!Advertise here!
Passive radiators 454Casull Subwoofers 18 12th January 2012 01:28 AM
Mini Passive Radiators villeneuve Multi-Way 1 16th January 2009 02:45 AM
Passive Radiators? Kensai Full Range 3 8th May 2006 09:37 PM
Questions re. passive radiators Dave Jones Multi-Way 8 3rd May 2004 06:47 PM
Passive Radiators surf,sun&sound Multi-Way 6 19th November 2001 10:39 AM
