Crossover for different impedance drivers
Old 29th September 2013, 07:02 PM   #21
R.I.P.
Crossover calculators are always wrong as they don't
include compensation for the baffle step, even if you zobel.
Take a look at : Zaph|Audio - ZA-SR71
rgds, sreten.
Also look at https://sites.google.com/site/undefinition/diy/amiga
The cabinet proportions are nicked from you know who.
Old 29th September 2013, 07:18 PM   #22
dragonweed is offline dragonweed  Hungary
Banned
Basically the Staff is a "redesign" of the Mite, in a floorstanding version, using a bass tuning yielding the deepest F-3 point from the given woofer. X-over is almost the same, but due to the somewhat higher efficiency, the tweeter resistor is a bit less. Make the X-over on a test panel, placed on the top of the box, so you can easily change the values, and expriment until you get the best sound for your taste and system. Actually this is how I did most of my design work.... Microtuning is essential, sometimes tenth of ohms, and 0.1 uf changes in the values can make or break your day. Most of these speakers were designed using a Roksan Xerxes t'table , Dynavector Karat 23 Ruby cartridge, Artemiz tonearm, a self designed tube preamp, and Roksan ROK S-1 power amp (one of my all-time favourite). Your system choice might call for slightly different values tough..... Good luck, if you need more help, send me PM.
Old 29th September 2013, 09:58 PM   #23
Inductor is offline Inductor  Portugal
Inductor's Avatar
dragonweed,
Do you mind I ask you where can I read more info (in book or "net" form) on the QM3 alignments, you mention on post #17. Can read English, French, Italian, Spanish, Portuguese. I will give a second read at your posts, they are interesting. Regards.
Old 29th September 2013, 10:35 PM   #24
R.I.P.
Originally Posted by dragonweed View Post
Speaker design software are a good starting point, but usually
have limited use when it comes to real-world drivers.
Not true at all as soon as you ignore the suggested alignments
and make up your own bass alignments, which you can easily.
rgds, sreten.
Old 30th September 2013, 04:02 AM   #25
AllenB is offline AllenB  Australia
Baffle compensation cannot correct for the baffle either though. Even partial compensation won't correct it. It is an in depth subject.
Old 30th September 2013, 12:44 PM   #26
Banned
Here is the article on the QM3 alignment. I think it is the "secret weapon" of reflex enclosure design, because it gives you almost limitless possibilities in choosing a box size and tuning for a given driver, with minimal low frequency ripple.
Old 30th September 2013, 03:44 PM   #27
Inductor's Avatar
Hi, and thanks.
Is that the ""Résonateur ELIPSON""?!
Regards.
Old 30th September 2013, 11:43 PM   #28
portreathbeach is offline portreathbeach  United Kingdom
I've been trying to get hold of some of the Tonsil drivers, but the couple of Polish companies who sell them haven't got back to me. Anyway, I also heard that Tonsil went bankrupt! is this true, and if so, what other drivers have very near characteristics as the drivers mentioned earlier in this post.
Or does anybody know where I can buy the Tonsil drivers from and ship to the UK?
Old 1st October 2013, 03:56 AM   #29
Inductor's Avatar
Default Tonsil GDN 13/40/2 8 ohm
portreathbeach,
I did a search and it seems that you are lucky, there are a few possibilities, more than you might expect.
1. Peerless 830860 HDS 134 PPB
http://www.tymphany.com/files/HDS-P8...20Rev1_0_0.pdf
Peerless 830860 HDS 134 PPB MidWoofer Speaker
The Madisound Speaker Store
Peerless 830860 5-1/4" PPB Cone HDS Woofer 264-1080
830860 - Peerless HDS-134PPB PPB diaphragm, 26 mm coil, AL - Europe Audio
troels design: peerless hds ppb 830860 + vifa xt 25tg 30-04 : Low volume tweeter
Peerless HDS PPB 830860
2. Audax HM130Z12
Haut-parleur grave médium Audax HM130Z12
Audax HM130Z12 (8Ohm)
3. Monacor SPH-5M
MONACOR INTERNATIONAL : New products
Monacor SPH-5M
4. Wavecor WF152BD04
WF152BD03_04
Wavecor WF152BD04 - Lautsprecher-Berlin
WAVECOR WF152BD04, 13cm bass/midrange driver, paper cone - Price per piece
5... I would consider many others variants, give a look, some might also be available in the UK.
Audax HP130Z0
http://www.audax.com/archives/hp130z0.pdf
HP130Z0 - RumoH - Caps, coils and speakers
Old 1st October 2013, 05:51 AM   #30
Banned
You should also consider the SB Acoustics 15 series midwoofers, which are excellent performers in a cca.1/3rd cu.ft. vented box. Falcon Acoustics used to sell them at reasonable prices. SB Acoustics :: MIDWOOFERS
Crossover for different impedance driversHide this!Advertise here!
calculate crossover with Re or impedance ? nickthevoice Analog Line Level 5 5th October 2013 12:21 AM
Impedance Of Crossover and Tweeter The Heater Multi-Way 16 19th April 2013 12:43 PM
Effect on crossover of using drivers of different impedance than original? Unimog Multi-Way 4 20th July 2012 12:18 PM
Crossover point and Impedance. Aguilabrava Multi-Way 20 3rd March 2012 03:50 AM
Crossover Impedance... Ignite Multi-Way 0 21st August 2001 10:23 PM
